Author Topic: Fitting a 6R (MK8) Polo steering wheel into a MK5? [RESOLVED]  (Read 12096 times)
Offline woahnowboys
« on: November 01, 2013, 05:13:04 pm »
I've found a steering wheel out of a 2011 Polo for £30.
Since I didn't want a MF, just a simple wheel, the Polo one seems perfect. :drinking:
Anyone know if it is a straight swap?
I've seen one in a MK4 before, but not sure if it took any work to get it to fit.
« Last Edit: November 22, 2014, 02:45:23 pm by woahnowboys »
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
Offline woahnowboys
Re: Fitting a 6R (MK8) Polo steering wheel into a MK5?
« Reply #1 on: November 09, 2013, 05:04:02 pm »
Don't know if anyone is interested in this, but I got my wheel and test fitted it.
Just waiting on the airbag now, and I can put it in properly. :smiley:
Altogether ended up costing about £200
I think it'll look awesome with the horn push :jumping:
MK5 Daily.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #2 on: November 11, 2013, 06:47:28 am »
Looking good :)
Offline OLLIE_JETTA_MK5
« Reply #3 on: November 19, 2013, 03:44:12 pm »
PM me with what heater contols you have please mate
Dubbin it since 2006
Offline woahnowboys
« Reply #4 on: November 19, 2013, 05:02:33 pm »
PM'd :happy2:
MK5 Daily.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: November 19, 2013, 05:59:59 pm »
I trust you have ordered the proper airbag, an easy mistake to get the wrong one with so many different versions
Cluster and Key coding
Location Great Yarmouth
Offline woahnowboys
« Reply #6 on: November 19, 2013, 07:09:37 pm »
I had a problem with the seller, so haven't got one yet, and my money is going elsewhere for now.
I'll probably get on this in the next few weeks.
What do you mean different versions? My plan was to get a polo 6R airbag and horn push and splice the mk5 connector onto the polo loom
MK5 Daily.
Offline woahnowboys
« Reply #7 on: November 19, 2013, 11:59:28 pm »
Eddie, would that be the right way to go about it do you think? I don't want to turn the key and have it explode in my face haha!
Thanks :notworthy:
MK5 Daily.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: November 20, 2013, 12:10:31 am »
the loom will work ok, but will need a bit of modifying to get the horn to work.
look at your wheel and see how the airbag clips in
and compare it with this one
http://www.ebay.co.uk/itm/VW-Golf-flat-bottom-GTI-steering-wheel-with-DSG-/121212560002?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c38d4e282#ht_583wt_1170
your wheel and the one above uses an airbag type like this
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-6-MK6-PASSAT-CC-SCIROCCO-GENUINE-DRIVER-AIRBAG-5K0880201-/190970050934?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c76b3b976#ht_2621wt_932
(although the one above won't fit your wheel)
Offline woahnowboys
« Reply #9 on: November 20, 2013, 12:17:38 am »
Okay, so the difference being that is a GTI wheel, but a non-GTI airbag?
Sorry if I'm not getting it :signLOL:
Also, what sort of modifications will I have to do to get the horn working?
Thanks for your help :smiley:
MK5 Daily.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: November 20, 2013, 12:23:42 am »
If you look at the GTi wheel there are 2 lugs
Look at the airbag and on the base that clips into the steering wheel there are 2x metal loops that clip on to the lugs
Compare that with your wheel which has 2 spring type clips (also lower than the lugs)
The airbag cover is correct for both the GTi wheel and your wheel, but the base is different
Hope you understand as I can't explain it any better
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #11 on: November 20, 2013, 01:32:30 am »
i had a similar dilemma a few months ago i bought a cheap mk6 mfsw without air bag to find out it was cheaper to buy a complete same wheel with airbag & eddie fitted it without any problems.
Offline woahnowboys
« Reply #12 on: November 20, 2013, 08:16:36 am »
Okay, I think I've got you haha, I just need to make sure I get a picture of the back of the airbag, so I can see if the fittings line up and are the same type of fitting?
Yeah I don't know why I didn't buy a complete wheel, would've been easier haha
MK5 Daily.
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #13 on: November 20, 2013, 01:08:26 pm »
Can you share with everyone what heater controls these are? eBay?
Offline woahnowboys
« Reply #14 on: November 20, 2013, 01:32:42 pm »
Of course.
I don't have access to a computer right now, so a phone screenshot will have to do. I'll edit this and add a link when I get in.
Should be easy enough to find from this though :smiley:
It's a MK4 set, the ones I bought are no longer listed :confused:
Don't quote me on this, from what I've read online, they are the same.. Probably worth looking into this though, I haven't found much info.
Sorry I can't be of more help.
MK5 Daily.
