August 31, 2026, 08:52:22 pm
All Things Mk5
Technical Workshop
Low pressure fuel pump pressure?
Topic: Low pressure fuel pump pressure? (Read 2350 times)
murph81
Taking part
-Given: 17
-Receive: 0
November 19, 2013, 06:53:37 pm »
I am fitting a BWJ TFSI engine in my Mk1 Golf Gti and just want to make sure that the standard pump is up to the task.
I need to know what kind of pressure the LPFP makes?
Cheers,
Adam
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Re: Low pressure fuel pump pressure?
Reply #1 on:
November 19, 2013, 07:48:19 pm »
You should see 5bar at start up dropping to around 4+ bar at upper rpm.
Also make sure you use the correct 6.6 bar pressure release valve fuel filter.
murph81
Taking part
-Given: 17
-Receive: 0
Reply #2 on:
November 20, 2013, 01:24:41 pm »
Thanks for the reply, I have an adjustable fuel pressure regulator and I have a gauge on the way so I can set it up and monitor it.
Would you still recommend that fuel filter, I have a fuel filter fitted, just not that type.
All Things Mk5
Technical Workshop
