All Things Mk5 > Performance Modifications
Engine shut down under boost - fail safe?
<< < (11/11)
vRSAlex:
--- Quote from: scopes on February 24, 2014, 11:55:44 pm ---
--- Quote from: richwig83 on February 24, 2014, 01:36:58 am ---Engine speed sensor.
--- End quote ---
Does or can this adjust idle speed??????
--- End quote ---
Nope.  It reads the speed.  The idle is in the mapping.
Get rid of the forge valve and try a rev G.  Could also be a small leak from the brake servo pipes.
scopes:
cheers Al
Will give that a try  :happy2:  Also where would be a good place to start searching for any leaks from the brake servo pipes ???
bacillus:
Probably cheaper to just get a new hose if there is any doubts for just under £29. And you will need the small green plastic bung as well if you get a new hose part #  056129777
http://www.mk5golfgti.co.uk/forum/index.php/topic,79635.msg827917.html#msg827917
scopes:
Thanks Ayoub, what can cause these to leak, would they be known to failure ?
scopes:
Anyone ever figure this out yet as the problem is still here...
 :sad1: :fighting: :fighting: :fighting:
Navigation
[0] Message Index
[*] Previous page
Go to full version
