October 19, 2026, 03:06:08 am
All Things Mk5
Mk5 General Area
Door Rubber Seals
Topic: Door Rubber Seals (Read 1449 times)
dav1e
Taking part
-Given: 3
-Receive: 1
Door Rubber Seals
February 28, 2014, 07:11:54 pm »
Hi, my rear passenger door seal the one on the bottom of the door has come unstuck - does anyone know what is best to stick it back down with so that it gives a good seal and doesn't let water in - thanks
Richie_101
Taking part
-Given: 2
-Receive: 0
Re: Door Rubber Seals
Reply #1 on:
February 28, 2014, 09:25:23 pm »
I had the same problem about 12 months ago, and I used impact adhesive and I haven't had any problems with leaks or it coming unstuck.
This is the stuff, you should be able to pick a tube up for well under a fiver.
Rich.
dav1e
Taking part
-Given: 3
-Receive: 1
Reply #2 on:
March 01, 2014, 07:28:21 pm »
thanks for that Rich Ill try some
Zseth
Taking part
-Given: 0
-Receive: 0
05 GTI DSG
Reply #3 on:
March 01, 2014, 09:53:27 pm »
I just did this to a mates car the other day, just used superglue gel
Worked a treat, impact adhesive should be fine as suggested, poor design by vw for seals to be just stuck o
All Things Mk5
Mk5 General Area
Door Rubber Seals
