All Things Mk5 > Mk5 General Area
Are these the correct size for the ED30?
cossy:
--- Quote from: Hurdy on October 16, 2009, 11:33:52 am ---Most aftermarket wheels at 18" tend to be 8" or even 8.5" wide. There are alloys you can get at 7.5" wide, but not many reputable ones.
Dotz aren't bad and are relatively cheap. I quite like this wheel, but the anodised finish isn't to my taste. Even this will stick out 6mm, but shouldn't have any rubbing issues. :smiley:
http://www.rimstyle.com/products/detail/?category=alloy_wheels;type=dotz_roadster_an;model=286;id=DOROAAN1875755112454512900
As long as you stick with an 8" or 7.5" alloy and keep to an offset of 45 to 51 , you should be okay :happy2:
I quite like them, any one here running them? pictures? Ta
--- End quote ---
cossy:
--- Quote from: stokeballoon on October 16, 2009, 11:37:17 am ---
--- Quote from: cossy on October 16, 2009, 11:17:11 am ---Thanks for the info. Think Im away now!
Is there any wheel or wheels out there the same size as the pescaras?
--- End quote ---
Pescara's?
still have one available.................
--- End quote ---
I might have four available if my credit card comes out in a minute!!
Hurdy:
No-one on here has the DOTZ alloys fitted, but I have seen them on a few MKV's and they look very good.
candy turbo:
on a lowered ed 30 pescara s with 10mm spacers rub the back arches they did on mine and on dan paynes with my wheels, so i would think you may have problems with these
Top Cat:
--- Quote from: candy turbo on October 16, 2009, 02:04:16 pm ---on a lowered ed 30 pescara s with 10mm spacers rub the back arches they did on mine and on dan paynes with my wheels, so i would think you may have problems with these
--- End quote ---
I agree it depends how much you lower it and how though, it seems to be pot luck what ride height you get with just springs. there are qiute a few people on here with the same springs but completely different ride height. Also the weight of the wheel comes into play, but at 10 or 12 mil futher out the rubbing would only be very slight and occasional in my opinion. :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
