Author Topic: whiteline (WALK) failure...  (Read 9863 times)
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 96
Re: whiteline (WALK) failure...
« Reply #15 on: October 20, 2009, 01:34:10 pm »
mine had lots of the grease in there  :confused:
What - between the inner and outer yellow bits?  You need to dis-assemble them from how they are supplied to get much more grease in them.  I'm guessing that on yours, only the metal hex end of the TCA was greased.  How many miles did yours do before they let go?
  • -Given: 88
  • -Receive: 96
« Reply #16 on: October 20, 2009, 01:38:12 pm »
I was thinking of having this fitted along with upgraded springs - not so sure now :surprised:  How many miles had the car done with the WALK?
The WALK makes a noticeable, if subtle diference even when the rest of the suspension is completely standard.  It improves self-centreing of the steering, straight-line directional stabilty, steering 'turn-in', steering mid-corner feel and stability - along with traction on turns.  Go for it, but make sure there is loads of grease applied to BOTH parts of the bushings.
Offline stiggy
« Reply #17 on: October 20, 2009, 01:45:54 pm »
Ok, thanks :happy2:  So the failure here is to do with fitment rather than the kit itself?
MkV GTI Edition 30 - 5 door - DSG - Diamond Black - RNS 510 - Now with a hint of blueflame.....
  • -Given: 88
  • -Receive: 96
« Reply #18 on: October 20, 2009, 01:58:39 pm »
Well - sort of stretching a theory to extremes on the failure bit.  Yes, the lack of grease will have a contributory factor to the failure - but there are probably also other issues too, such as severely lowered suspension (which the yanks seem to be keen on), other modified suspension components, being a track whore, etc.
As Tony Danza stated, Whiteline have a very good reputation, and I strongly bet that there are considerably more users of the WALK who have had ZERO probs with them, compared to two worldwide published failures!  :wink:
« Reply #19 on: October 20, 2009, 02:18:11 pm »
cleaned all the crud and grease off my old ones so u can see the split
  • -Given: 88
  • -Receive: 96
« Reply #20 on: October 20, 2009, 02:23:47 pm »
Hmmm . . . that doesn't actually look like a 'failure' - because the main 'body' of the bush is still perfect.  Or have I missed sommat?
Offline tony_danza
  • -Receive: 112
« Reply #21 on: October 20, 2009, 02:24:40 pm »
I think I was one of the first to fit them, over 12 months ago - done 15k, 2 ring trips and 5 track days. I have the car checked after each event and they're still 100%.
They've been making these for Subarus for years, so it isn't exactly new technology.
I'd say:
Dodgy batch.. or most likely incorrect fitting, failure to align suspension properly after fitting or as TT said and IMO too, dry joints.
Sideways yo!
« Reply #22 on: October 20, 2009, 02:25:40 pm »
the one on the left the end split and the one on the right split down the middle oh and this is the inner bush
  • -Given: 88
  • -Receive: 96
« Reply #23 on: October 20, 2009, 03:04:02 pm »
Yeah, it was your rather excellent report on the 'dark side' which got me spreading their praises on the GTI forum. :happy2:
And anyone who knows me by know will understand that I'd only give the thumbs up to products which actually make a positive benefit for the average to enthisiastic road user - and these really do hit the sweet spot. :wink:
Has anything else worn out in that timescale and useage?
I'd say:
Nice to know we agree on somat!  :evilgrin:
  • -Given: 88
  • -Receive: 96
« Reply #24 on: October 20, 2009, 03:06:00 pm »
Ahhhhh - I see the split in the right one.
Maybe your next mod ought to be a  . . . . . better camera! <ducks for cover>  :evilgrin:
Where?  :chicken:
« Reply #25 on: October 20, 2009, 03:08:56 pm »
its a 2 bush item ie one big outer bush and a smaller one inside and the pic was just a quick one and if u like i will take them to a better location and get the tripod out and use my better cam  :P
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #26 on: October 20, 2009, 03:29:15 pm »
I'm also at > 15k miles on the WALKit and its fine , I havent done track days nor have danza's talent but I dont hang about either  :driver:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #27 on: October 20, 2009, 03:31:15 pm »
i did over 30k on mine
Offline tony_danza
  • -Receive: 112
« Reply #28 on: October 20, 2009, 06:20:58 pm »
I'd say:
Surprisingly, nothing has failed or worn at an abnormal rate given what it has had to deal with. My old MKIV would have certainly been through a set of topmounts and wishbone bushes in the same circumstances.
Mat, did you ever grease the bushes in that 30k? I try doing it as often as I can with white lithium.
Sideways yo!
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #29 on: October 20, 2009, 10:18:58 pm »
How did you notice that they were failing?
