All Things Mk5 > Performance Modifications
After an new air filter...
<< < (3/3)
SurreyED30:
VWR make panel filters mate, I've rear there quite good but around £40-£50 mark iirc
alexharvey:
im sure the VWR panel filters are made by ITG
SurreyED30:
^ correct mate
GrayMK5GTI:
--- Quote from: Gene Hunt on June 04, 2014, 01:42:56 pm ---
--- Quote from: richwig83 on June 04, 2014, 01:30:26 pm ---
--- Quote from: Gene Hunt on June 04, 2014, 12:19:46 pm ---What is the best panel filter to get please?. Want to keep the o.e look. :smiley:
--- End quote ---
OEM paper filter is fine.  :happy2:
--- End quote ---
.........thanks. :happy2: Running that now just wondered if any of the '' performance panel filters'' were any better?.
--- End quote ---
Didn't I answer that above?
56OctyVRS:
I ran a paper filter at stage 2+ and it ran perfectly fine. Tried performance filters and there was no perceivable difference. Just change your cilter every 10k and you will be fine.
On my current car I have tried K&N and Pipercross and I still cant feel any difference in performance over std.
If you research independent filter tests; there is a 0.90% pressure drop difference between the highest flowing filter and the std paper filter. That means there is very little flow difference between them all.
Navigation
[0] Message Index
[*] Previous page
Go to full version
