Author Topic: Can anyone recommend medium length breaker bar  (Read 4278 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=gjnbafkesof34pq9nbmlss90h2&/topic,90967.msg917089.html#msg917089
« on: September 27, 2014, 08:06:31 pm »
I'm looking for a medium length breaker bar for the more delicate bolts that my 600mm bar will break and my standard ratchet wont budge. Preferably 1/2 inch drive.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Can anyone recommend medium length breaker bar
« Reply #2 on: September 27, 2014, 08:28:43 pm »
I already have that one its great. I need something smaller that will hopefully stop me snapping everything.
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #3 on: September 28, 2014, 01:34:17 pm »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: September 28, 2014, 02:00:27 pm »
Offline Golf_GT_TDI
  • -Given: 45
« Reply #5 on: September 28, 2014, 02:14:03 pm »
Yeah it's just right, I use Halfords Pro torque wrenches but my breaker bars are Snap-On/Bluepoint
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: May 01, 2015, 01:06:00 am »
Resurrecting an old thread. I purchased the Snap On breaker bar recommended by @Golf_GT_TDI . Its great.
The cheap 24" breaker bar i bought from amazon is starting to crack.  :confused:
Although the reviews are good i think its  :booty:
Luckily i managed to get 90deg on my drive shaft bolt earlier today without it breaking and smashing me in the face or even worse hitting the car.
http://www.amazon.co.uk/gp/product/B000O619PA?psc=1&redirect=true&ref_=oh_aui_search_detailpage
Where can i get a 24" Snap On Bluepoint from??
Offline Golf_GT_TDI
  • -Given: 45
« Reply #7 on: May 01, 2015, 11:59:15 am »
Wow lucky with that breaker looks like it could of let go any moment.
Sealey also do a 3/4" drive 1m breaker that is a better bet for the driveshafts, along with Laser's 3/4" driveshaft impact socket it gets the job done but 3/4" is not needed otherwise on the car.
The Snap-On 1/2" drive 24" breaker bar goes by part number SHBB24 and there is one on eBay at the moment...
http://www.ebay.co.uk/itm/Snap-on-Flexi-Head-1-2-drive-Breaker-Bar-24-inches-SHBB24-/400911176854
EDIT: The Sealey 1/2" is also available in the Platinum Series version:
http://www.sealey.co.uk/PLPageBuilder.asp?gotonode=ViewProduct&method=mViewProduct&productid=17383&productdescription=spring&productcode=&category=7&catgroup=123&catmicrogroup=&analysiscode=&requiredresults=16
« Last Edit: May 01, 2015, 12:06:14 pm by Golf_GT_TDI »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: May 01, 2015, 12:14:14 pm »
Do you think the snap on or sealey 1/2" bar can handle the drive shaft bolts?
Offline doylebros
« Reply #9 on: May 03, 2015, 01:49:28 pm »
70 NM is the torque setting for the CV joint bolts so both those power bars should handle that easily.
Snap on is the better bet since they change it if it developed any defects as your previous bar from Amazon.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #10 on: May 03, 2015, 02:00:04 pm »
Its the main drive shaft bolt that does the damage 70nm plus 90 deg
Offline doylebros
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #12 on: May 03, 2015, 02:21:50 pm »
item 2.
Offline doylebros
« Reply #13 on: May 03, 2015, 02:29:42 pm »
I only torque item 2 to 70NM in two stages - where did the plus 90 come from?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #14 on: May 03, 2015, 02:36:39 pm »
The main bolt (item 2) is 70 Nm + quarter turn (90°) ??
