All Things Mk5 > How to Guides / Troubleshooting
Horn! It sounds with the turn off the key but won't work off the wheel....
<< < (2/2)
jason_rmh:
In vcds steering control module. You see a code in the long coding section.
Vcds will tell you what each digit means so you can build up your code to put in the box.
Jas
Navigation
[0] Message Index
[*] Previous page
Go to full version
