Author Topic: Side light replacement on xenon headlight question...  (Read 1872 times)
Saintsteve
« on: December 15, 2014, 04:36:14 pm »
Does or has someone out there managed to change a sidelight bulb in a xenon headlamp on the Mk5?? Not the standard halogen lamp unit, as they are a lot easier!
Any tips, drivers side without avoiding dropping the front bumper off :sad
Offline H18Golf
Re: Side light replacement on xenon headlight question...
« Reply #1 on: December 15, 2014, 04:58:33 pm »
Just done this yesterday.  The passenger side isnt too bad as you can see the orange/brown connection to the sidelight bulb, i was able to pull this out with my fingers.  Other people have said to use long nose pliers or pliers that have a 45 degree angle to them.
The driver side isnt as easy, i couldnt get my fingers near the connection.  I basically put the cabling round my finger and rocked it up and down and pulled slightly at the same time and the bulb came out.  I would just over emphasise dont just pull at the cables.
Hope this helps mate.
Offline Matto
  • -Receive: 116
« Reply #2 on: December 15, 2014, 05:04:37 pm »
Not sure with the petrol engine but the fuel filter is behind the drivers headlight on the diesel. I find just unbolting that gives enough room to get your hand in. Just remember they pull out as opposed to quarter turn out.
Offline H18Golf
« Reply #3 on: December 15, 2014, 05:06:54 pm »
The petrol is different as you thought Matto.  But like you said, no quarter turns etc, they need to be pulled out.
« Reply #4 on: December 15, 2014, 07:50:11 pm »
It was easier than with halogens. Just find the orange brown connector and pull.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #5 on: December 15, 2014, 08:47:08 pm »
Mine after 6 years were pretty stuck so I had to use force, long pliers and eventually a friend came by and helped out too.
I bet now they're easy to pull out.
