All Things Mk5 > Performance Modifications
Bilstein b8 dampers questions. Mk5 vs mk6. Stiffness etc
<< < (2/2)
skard:
To be fair, I noticed the Koni's were leaking not long after buying the car, and had been wiped down.
I am returning my car to completely standard to sell it, that is the only reason why I took them off - they are fantastic.
jedi-knight83:
Does the mk6 b8 still offer an improvement / upgrade over the oem mk5 damper then?
jedi-knight83:
Wonder what the oem damper compression figures are compared to these then
Shoduchi:
--- Quote from: jedi-knight83 on January 30, 2015, 12:15:04 pm ---Thanks for the replies
--- Quote from: skard on January 29, 2015, 11:43:14 pm ---I took off my mk5 B8 kit today and replaced it with OEM - I think they're a very similar ride.
My car came with Koni FSD on and it felt like I was being slapped in the head every time I went over bumps
--- End quote ---
So the koni were too stiff
Why did you remove the bilsteins?
--- End quote ---
There are two Koni FSD kits available for the mk5 chassis. The first Koni made is the Kit 2100-4001, which is the one that I got (with Eibach Pro-Kit springs). But due to some complains about it being too soft, Koni made a stiffer kit for the GTI, Kit 2100-4090.
If you want comfort and still a good handling, I'd get the same kit as I have. If you want a more stiffer ride, more track oriented, you can get the GTI kit: 2100-4090.
You can read more about this in this review topic: http://www.mk5golfgti.co.uk/forum/index.php?topic=55600.0.
Beddie:
--- Quote from: jedi-knight83 on January 30, 2015, 12:37:09 pm ---Does the mk6 b8 still offer an improvement / upgrade over the oem mk5 damper then?
--- End quote ---
Yeah the mk6 version offers a big improvement over the OEM damper imo  :happy2:
The thread I linked has quite a few people running the mk6 B8 on mk5s
Navigation
[0] Message Index
[*] Previous page
Go to full version
