Author Topic: Dog Bone Bush With Miltek  (Read 1662 times)
Offline Madone
  • -Receive: 27
« on: March 29, 2015, 09:09:47 am »
Hi,
Fitted my new turbo back Miltek yesterday and included in the box it transpires was a SuperPro Lower Torque Arm insert bush, however as there was no instructions or reference to what it was we didn't fit it. After a bit of research i now know what it is.
Is the worth fitting ?,what are the downsides ?, more vibration etc ?
How hard is it to fit, its a real pain as the car was on the ramp yesterday and would have been much easier then i am sure !
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3oogqf4ll4id18g38flkndb6at&/topic,19740.0.html
Re: Dog Bone Bush With Miltek
« Reply #1 on: March 29, 2015, 09:11:38 am »
It takes 5 mins to put it in. Not much extra vibration... but helps to stop the engine rocking and destroying weak exhaust hangers.
Offline Madone
  • -Receive: 27
« Reply #2 on: March 29, 2015, 10:13:02 am »
Can it be done on axle stands ?, I don't want to have to go back to the garage that fitted the exhaust.
Offline bigmig95
  • -Receive: 50
« Reply #3 on: March 30, 2015, 12:17:27 pm »
Did mine on axle stands  :happy2:
Offline NickG60
« Reply #4 on: March 30, 2015, 09:10:52 pm »
Did mine on the driveway, car on (railway sleeper) ramps. As long as you have a torque wrench, it really is just a case of undoing one bolt, greasing up insert, sliding in then doing it back up.  I believe tightening torque is 74 ft/lbs , plus do a quarter turn once at correct torque. (check that torque tho).
I have no extra vibration, in fact the engine used to transmit a slight shudder occasionally at tick-over (prob a slightly dirty injector i thought), this has gone now with the bush added. So I 'know' it reduces movement, but I reckon any other effects I can feel are probably placebo.
Offline PSItuning
  • Trader - 2014
    • PSItuning.com
« Reply #5 on: April 06, 2015, 11:39:16 am »
The standard bushes wear quick on a standard car, with the downpipe the bush will wear quicker hence why they are now included with Milltek downpipes :)
http://www.psituning.com
Suppliers of ECS Tuning, Milltek, KW, AP, Revo, Forge, Wavetrac, Brembo, Superpro, Newsouth, CTS Turbo, Powerflex, VWR, Jetex, Polybush, Vibratechnics, K&N, Green Filters, Tarox, Meguiars, H&R, Eibach to name a few!
Offline Madone
  • -Receive: 27
« Reply #6 on: April 06, 2015, 03:49:33 pm »
Fitted it on the drive, fairly simple to do and made a massive difference !, well worth doing !, no  extra vibration but a massive improvement in gear change and general engine movement
Cheers all  :happy2:
« Last Edit: April 07, 2015, 11:25:25 am by Madone »
