Author Topic: Aircon not working  (Read 5644 times)
Offline caviarjim
Re: Aircon not working
« Reply #15 on: April 25, 2015, 10:50:27 am »
Ok thank you for the advice. Think I will take if in to my local dealers next week and get them to do a diagnostic.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #16 on: April 25, 2015, 10:54:47 am »
My ED35 air con has started to play up, not blowing cold. Dealer did a quick temp check the other day & on it's lowest setting was showing 24.5 & still getting warmer. Car is still under warranty so is booked in for more work.
Offline akbarirfan
  • -Given: 81
« Reply #17 on: April 25, 2015, 05:04:02 pm »
@skard which blocks need measuring mate?
Offline skard
  • -Receive: 245
« Reply #18 on: April 25, 2015, 05:05:16 pm »
In engine ECU, flick through and you shall see AC. Also, 08-HVAC
Offline akbarirfan
  • -Given: 81
« Reply #19 on: April 25, 2015, 07:09:57 pm »
Cheers - so I should see the number change between switching the AC on and off?
Offline skard
  • -Receive: 245
« Reply #20 on: April 25, 2015, 07:38:36 pm »
Yeh and a popup list should be present with what the code means should be there
Offline caviarjim
« Reply #21 on: May 02, 2015, 01:09:54 pm »
Well, have had the diagnostic done and it looks like I need a new compressor. Can anyone recommend a supplier? Don't really want to go to the stealers! Also does anyone know what the part number would be?
Offline white91
« Reply #22 on: July 03, 2015, 11:48:00 am »
Did you ever get this sorted?
Offline Rampage
« Reply #23 on: July 03, 2015, 12:19:03 pm »
I'd be interested to know this too. Is there a different code if it's the pressure switch as opposed to the compressor itself?
Does anyone know the latest revision part no. for the pressure switch?
Cheers  :happy2:
Offline doylebros
Offline caviarjim
« Reply #25 on: July 03, 2015, 09:12:04 pm »
In the end I ended up having to fit a new compressor. Bought it from Advanced Radiators. Very good service it cost me around £200 shipped and my local garage charged me a couple of hours labour to fit it. I now have nice cool air again!☺
Offline Rampage
« Reply #26 on: July 04, 2015, 10:02:31 am »
Thanks gents, much appreciated!
Cheers  :happy2:
