All Things Mk5 > How to Guides / Troubleshooting
LPFP - Bit of help please
MateyGuv:
Looks like the problem is with the LPFP. I think I'll try the sensor first then look into the pump. Do you know where the sensor is Dave? @Dave J
I do have a 4WD LPFP, anyone know if this can be used??
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G93NM7R3
Coding: 040300031C070160
Shop #: WSC 01279 785 00200
VCID: 377D17514684DB999F5-8062
2 Faults Found:
004767 - Low-Pressure Fuel Pressure Regulation
P129F - 001 - Pressure too High - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 71727 km
Time Indication: 0
Date: 2015.04.22
Time: 22:23:54
Freeze Frame:
RPM: 1094 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 19.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.097 V
012555 - Low Pressure Fuel regulation
P310B - 001 - Fuel Pressure Outside Specification
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 71727 km
Time Indication: 0
Date: 2015.04.22
Time: 22:24:53
Freeze Frame:
RPM: 1049 /min
Load: 18.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 18.0°C
Voltage: 14.224 V
Readiness: 0110 0101
MateyGuv:
@fuscobal
Is it as easy as your build thread seems, do I need coding done or is it plug and play?
Any help would be great mate :happy2:
fuscobal:
Was plug and play for me with only the floating mechanism mod ! TTRS pump should be ok with no software mod but could burn the OEM controller, in which case you should also buy the TTRS one ! For me the OEM controller worked fine and I've had a few track days with it on the TTRS pump !
MateyGuv:
Thank you dude :happy2:
MateyGuv:
Iv replaced the thrust sensor and it appears to be fine now - fingers crossed!! Thanks guys :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
