Author Topic: Help with xenon headlamp internal  (Read 3100 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« on: June 01, 2015, 06:24:22 pm »
Hi all.
Bought some xenons and the driver side one has a bit of the metal round thingy quite loose.
Any way of placing it back on?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Help with xenon headlamp internal
« Reply #1 on: June 01, 2015, 07:47:36 pm »
Should snap back into place, you'll need to carefully take out the lense and bracket and carefully find a suitable tool to just hook over the edge and gently pull back towards you.
I had the same problem a few years ago and it worked for me  :happy2:
Just a tip, put some cloth over what ever you use as the silver will scrape away quite easily if you have bare metal against it. As i found out the hard way  :sick:
« Last Edit: June 01, 2015, 07:49:42 pm by fab5freddy »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=igd0slh3oihbqo8l8o00ingd5o&/topic,19740.0.html
« Reply #2 on: June 01, 2015, 07:53:46 pm »
Yes... I had the same on mine. Took me 2 hours to bend bits of wire to form a hook to insert into the unit and pull it back.
AB-SO-LUTE ball ache!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: June 01, 2015, 07:54:31 pm »
Thanks for the response buddy.
Do i need to split them using a heat gun ot anything?  Or will the lens come off just by taking off the black hook things
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: June 01, 2015, 08:00:21 pm »
No heat gun needed matey, from memory once you've removed the igniter and bulb holder you can remove the bracket that holds the lense with 4 screws, just go easy and take your time.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: June 01, 2015, 08:07:42 pm »
Just re read your last post. Just to be clear, your not going at it from the front, you need to come at it from behind, through the black cap that unscrews to access the igniter/bulb etc  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: June 01, 2015, 08:09:14 pm »
Aaah i got ya.  Okay ill give that a try.
Looked for some videos earlier on how to split the light but no luck
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: June 01, 2015, 08:09:43 pm »
Cheers Rich.  At least it is fixable lol
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: June 01, 2015, 09:33:25 pm »
Thanks for all the input guys, just took the projector ball thingy out using by undoing the 4 screws and have clipped the metal ring back in place.
Will put it on the car tomorrow and see if theres any issues.
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #9 on: June 07, 2015, 12:01:45 am »
Same thing happened when I purchased a set of slightly damaged xenons. In the end I used my fingers to get a catch on it and pull it into position = no problems since!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: June 07, 2015, 01:01:08 am »
Cheers bud.  I did the same thing.  all sorted now
