All Things Mk5 > Performance Modifications
Intake Manifold Flap Motor v157
<< < (3/3)
yarickpi:
did I misread the question? you seemed to be wondering if when installing your new intake manifold if you should do VTCS delete as well, and I responded by saying that the VTCS is located in the stock manifold so by switching manifolds you will already be removing VTCS.
NotNormal:
@SeyiiOluwa they really need to be adapted via VCDS to make the most out of the new part.
If you're local to Lincoln PM me and i can sort it for you. Otherwise, look on the VCDS register on here and PM a local person
Hope it helps
Tom
SeyiiOluwa:
--- Quote from: yarickpi on July 13, 2015, 04:44:59 pm ---did I misread the question? you seemed to be wondering if when installing your new intake manifold if you should do VTCS delete as well, and I responded by saying that the VTCS is located in the stock manifold so by switching manifolds you will already be removing VTCS.
--- End quote ---
I was wondering why the car didn't improve in performance after repairing the manifold wiring and the EGR
SeyiiOluwa:
--- Quote from: NotNormal on July 13, 2015, 06:58:44 pm ---@SeyiiOluwa they really need to be adapted via VCDS to make the most out of the new part.
Hope it helps
Tom
--- End quote ---
Thanks for the help, is this the same even for an EGR replacement ??
NotNormal:
--- Quote from: SeyiiOluwa on July 18, 2015, 03:14:38 am ---
Hope it helps
Tom
--- End quote ---
--- End quote ---
No, erg replacement is a straight forward swap - no adaption required
Navigation
[0] Message Index
[*] Previous page
Go to full version
