Author Topic: Why a Mk7 area but not Mk6??  (Read 2076 times)
Offline Gaz
« on: August 04, 2015, 09:13:21 pm »
Obviously we are on the Mk5 forum, but theres a Mk7 section, so why not Mk6?
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Why a Mk7 area but not Mk6??
« Reply #1 on: August 04, 2015, 09:30:20 pm »
The mk6 is essentially an updated mk5, there aren't that many changes fundamentally, whereas the mk7 is a whole new car compared to the mk6.
It probably made sense as a lot of technical info for the mk5 would also apply to the mk6, so it maybe kept things a bit simpler than having two sections for the 'same' car.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: August 04, 2015, 10:06:43 pm »
There was a separate forum for the Mk6 at one point.
May be worth having a separate section for the EA888 engine still.
« Last Edit: August 05, 2015, 12:36:10 pm by sub39h »
PLANS: Stage 2+
Offline xjay1337
  • -Receive: 377
« Reply #3 on: August 05, 2015, 09:16:08 am »
no point, it'll only be full of "my timing tensioner failed and lunched my engine" posts.
Offline doylebros
  • -Receive: 310
« Reply #4 on: August 05, 2015, 08:38:17 pm »
Now the common problem on the MKVI with the CCZB engine is this http://www.autoserviceprofessional.com/article/93400/noisy-audi-chain
Search for supporting document :-
15D6 UPDATE - Camshaft Adjuster (LNVW).pdf
A lot more difficult to deal with than the above since bearing bridge gauze breaks up and works its way into the camshaft adjuster - fault shows G40 but is big money fault!
« Last Edit: August 05, 2015, 08:41:48 pm by doylebros »
Offline xjay1337
  • -Receive: 377
« Reply #5 on: August 06, 2015, 11:00:06 am »
Bloody hell that's less than idea.  :chicken:
