All Things Mk5 => Mk5 General Area => Topic started by: haribo_golf on November 11, 2020, 05:05:43 pm
Hi all,
My first post here - I've read lots of threads about cruise control but my issue doesn't quite seem to fit with what I've seen...
It was working fine until the beginning of last week when a brake light bulb went. I have replaced the bulb (two different ones to be sure) but still not working.
I have scanned with VCDS and found one possibly relevant fault:
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GD3N68I6
Coding: 0403000318070160
Shop #: WSC 01279 785 00200
VCID: 3460ABB0579C70EF73-8060
2 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166661 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 24
Reset counter: 255
Mileage: 167056 km
Time Indication: 0
Date: 2000.00.00
Time: 15:31:50
Freeze Frame:
RPM: 341 /min
Load: 41.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.430 V
I don't think these would cause cruise to stop, but happy to be told otherwise. I have the MAF fault on the list as well!
I have also run the live diagnostic and could see the brake and clutch switches changing the second field but none of the stalk buttons made the fourth field change. I'm using this for reference: http://wiki.ross-tech.com/wiki/index.php/Checking_Cruise_Control_using_Measuring_Values
At the moment I'm thinking I need to replace the stalk? Any advice appreciated.
Thanks, James
