All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Eddie-NL on October 31, 2014, 01:54:20 pm
I just fitted a new style Cluster (from a 2010 golf plus) into a 2007 Golf GT
Parts required Cluster (Scirocco or Golf Plus)
Adaptor Loom
2x new transponders
&feature=youtu.be
Legend!
What part number clocks would be needed?
I will have a look and post up some part numbers
I think on early cars they would also require a newer ABS Pump
Don't, Ed. I already want the white clocks in the Tig as it is..!
Great work as usual.
you know you want colour ones
Well, yes.
OH MY SWEET JESUS! :surprised: :surprised: :surprised:
You sir are a legend!!! I need these in my car now! I have a 2005 GT TDI what will i need to change?
first you need to find out what ABS module you have
Nice job sir :happy2: what is required as regards the wiring adaptor?
Want these in my Jetta TDI :jumping:
Pin outs are different between the 2x clusters
and the plug is in a different place
So an adaptor has the pin outs OLD > NEW
You could solder some wires to the existing but using the adaptor made it easier
:notworthy: great to see you keeping up the mods for us MK5 people! :happy2:
Just done a quick scan and my ABS is....
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl?
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023170
Shop #: WSC 00046 412 00000
VCID: 3A7B2816759A24CE953-806F
Not sure what you wanted to know so I got everything...will this need changing and if so what to? :innocent:
A MY09 GT Sport 1.9 TDI has the following:
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Would it be compatible?
great mod Eddie :happy2:
would this eliminate the error code with the newer mk6 climate panels the missing message one ?
I think it would, I've seen a scan of a 2004 golf which had a newer cluster fitted with a late BT mk6 climate panel and it didn't have the missing message fault.
Coding: 0023170
That one is too old
This one is ok 1K0 907 379 AC
Revision: 00H35001
Yes[/list]
Nice work Ed. Was just thinking I have a MK6 highline cluster in the cupboard. Shame its a petrol version.
White ones bought for now :party:
Eddie I did PM you but not sure if you got it
I want a (blue needle) R-Line TDI cluster on my Scirocco... It's the Mk6 one so already has a similar dash to the one in your retrofit.
Can you do it?
New or from ebay? Which part number did you go for?
Do you still have a tdi?
Jas
For my Tiguan
Can you do it?
I can fit one, the hard job is finding one
That one is too old
Thanks! :happy2:
Is it hard to change? I know the ABS unit will need to be changed and properly some coding is involved but anything else?
That one is too old
Thanks! :happy2:
Not that hard, coding will be the same. Bleed the brakes and do basic settings with vcds.
Oh thats great then! :happy2: :happy2:
Have you got a part number for the Clocks? I can't find any anywhere :indifferent:
Ed coded my new Tiguan cluster and chips remotely. Gives the dash a much fresher look compared to the old red block, which I am increasingly growing bored of :happy2:
Thanks once again Ed
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fonlinephoties%2Ftiguan%2F6DEB0F34-DD44-4F47-9AD1-7CF95FC0BE00_zpsmbthsap3.jpg&hash=85202215544b66b492100a4af8974398ce0a6489)
^ Nice.. I know what you mean about the All Red, it's a bit Dot Matrix in era - not something I'll be swapping this side of a different car though tbh.
Sadly I am still stuck with the red MFA in my Golf. Our last four cars have had the same ugly screen, might keep this one now, well until I find colour clocks!
Thanks David
Any word on a part number for the clocks? :smiley:
any of the below should be ok
RHD and MPH
always check the dials to see where the red line is and check the scaling for MPH
Golf Plus
Diesel
5M0 920 970F
5M0 920 970J
5M0 920 970B
5M0 920 971A
5M0 920 972A
5M0 920 973A
5M0 920 973
5M0 920 980A (Colour Display)
Petrol
5M0 920 970D
5M0 920 970H
5M0 920 971
5M0 920 980 (Colour Display)
5M0 920 972
5M0 920 973
Scirocco Clusters
Diesel
1K8 920 972A
1K8 920 980A (Colour Display)
1K8 920 973A
1K8 920 983A (Colour Display)
Petrol
1K8 920 972
1K8 920 972D (Scirocco R)
1K8 920 973
1K8 929 973B (Scirocco R)
1K8 920 980 (Colour Display)
1K8 920 980D (Scirocco R Colour Display)
1K8 920 983 (Colour Display)
1K8 920 983B (Scirocco R Colour Display)
Hey ed ,impressive work you had done on theese cars mate ,i have a question. I have a 2004 mk5 1.6fsi ,would it be possible to fit a colered or white cluster on mine? i was looking in to buy a highline cluster ,the red one , but i found this topic and raz's ride topic ,and i'm in love. cheers mate !
Red one can be easily done, for the coloured one I think it depends on which ABS module you have.
Eddie can verify it for you though :)
thanks for the reply ,considering my mk5 is '04 , i think i need a newer one. cheers raz
2004 - 2006 probably need to upgrade to a newer ABS pump (this could have happend due to VW wanting to replace ABS pumps due to the G201 fault before they started doing goodwill and releasing a repair kit)
Older cars would also require a newer Gateway
I understand ,i found a '08 cluster for my mk5 ,can it be fited on my car? Cheers
yes
Dare I ask the cost of the Scirocco cluster new from VW?! It would look fantastic.....but my wife is sure to notice!
a new cluster is around £800 from vw
Hi i have 3 sets of scirrocco white display full fis clusters for sale let me know if interested will work with eds magic in the mk5, these are the 180mph style ones in classifieds
Hey guys, i'm having a difficult time finding a cluster for my car , i have a '05 petrol mk5. I found some clusters of a 2008-2009 mk5 ,beautifull ,and very cheap. My problem is ,i read about this retrofit and learned it's very hard to adapt a immo4c cluster on my car. Can anyone help me with a thread ,or someone who can help me? What kind of gear ,gadgets, and so on i need for this to happen. Thanks in advance.
You need someone with the tools that Eddie-NL has + his expertise.
It might help if you give your location
i'm not from uk ,it would be great to have someone here where i am with the skills of eddie. The codding of a immo4c cand be done remotely ? i would pay full price via paypal if someone could help me code them remotely. cheers
where are you?
I'm from romania eddie...
Transylvania District?
Nearby mate , a couple kilometers south. Cheers
I've been there few times. Timisoara, Craiova and Pitesti, delivering machinery. Sorry for the OT guys
Searched all over the place ,on all possible forums and subforums ,nobody can help with remotely codding my cluster.. cheers guys !
if it was possible than i would
the problem is you can gain remote access and do the job but the tool to read your immo is not where your car is.
Hey guys ,managed to get some pritty awesome GTI clocks ,of a '05 ,perfect for my car. I have a single problem with them. The clocks where on a uk spec gti ,so the dials are in miles. I'm from estern europe so i would like to convert them in km. I know i can convert them using vagcom but i would like to change the whole dial into a km. Anybody done this ,do you know any company that produces just the dials ? cheers and thanks in advance
Just get the foils for it.
I have on my mk5 Jetta the the following ABS pump. (only ASR, without ESP).
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00066 000 00000
Is it possible for me to upgrade to the white / color clock without changing the ABS pump?
Thanks.
Hi @Eddie-NL (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2345) , sorry for re bumping this thread.
I have found this version of the color clocks (5n0920882c) which is 2012+. Will it work with any of the 2009+ ASR only ABS pump that you posted earlier in this thread? Right now I have "1K0 907 379 P" installed on my car, which I know it won't work
Works ok:
1K0 907 379 Q
1K0 907 379 AA
1K0 907 379 AC
1K0 907 379 AF (non ESP Caddy)
The reason I am asking you this, it's because I may have an opportunity to upgrade only the ABS pump real cheaper than doing the ESP retrofit to my car :happy2:
Hello,
Can you help me with some info regarding an instrument cluster that I found for sale on ebay:
The part no. is 5M0-920-971-A. Is this instrument cluster highline? Does is shows the car with the opened doors and the audio, navi and phone menu?
Thank you.
that is a highline
what displays will depend on what you have fiited to your car
Will have to bump it up. Need some help.
Hello Ed . Bought staff off u on eBay and then I found u on gti forum, that u retrofitting white/colour clocks to mk5 platform. The question I have for u now is what would I need to do it on mine golf 2004 gt tdi 2.0 ?
Know the abs pump, clocks and adapter, what I've already bought. Clocks are 5M0920970BX and the abs pump/module is 1K0614117S - PUMP 1K0907379AK - MODULE. Have the gateway changed already for 7no AM. Will the abs pump straight fit or is the plug different pinout and the pipes have different ends? That's what I was told or can I just change the module on the old pump. Car has ESP button in it. Is it doable at all ?
Cheers Seb
Cheers Seb
If changing to a much later ABS pump, in 2004 golf, you may need to change from gen1 to later (gen3) steering rack also......
Which MK70 ABS controller would be best to work with a white cluster? I seen part numbers for the MK60 modules but not a MK70.
My car had a MK70 ABS unit consiting of a 1K0 907 379 P ABS controller with 1K0 614 117 H ABS module.
Coding was 0017025
(No TPMS and standard suspension)
I tried replacing with a unit from a Caddy but the brake lines was different so I ended up putting the Caddy controller (1K0 907 379 AF) onto my ABS module but couldnt get the coding correct.
On my cluster, both ABS and ASR lights are on
Current Coding is 16641 (it didnt want to accept 0017025 even if the values from 404 Not Found) adds up to that)
and error code is
01044 - Control Module Incorrectly Coded
003 - Mechanical Failure
Can anyone help me out?
Sent from my SM-N920I using Tapatalk
Works ok:
1K0 907 379 Q
1K0 907 379 AA
1K0 907 379 AC
Did you ever work this out stonecold?
I tried replacing my P controller with an AF from a Caddy but now cant get it coded with the ABS and ASR lights burning on my cluster
Coding was 0017025
and error code is
Your issue is due to wiring
Change the wire from pin 25 to pin 15
Great thanks Eddie.....so just to make sure, the AF controller from the caddy is ok and will work when I just move the pin you mentioned? (Havent looked yet but its not 2 wires to swap, just 1 to move right?)
Then the coding in VCDS will work?
Eddie, I just managed to have a look at the wiring on my car and there doesnt seem to be a wire in 25.
Not sure if its just a bit hidden but I first wanted to look before I strip the battery box out to get more access.(https://uploads.tapatalk-cdn.com/20180202/200cc4491e58bb503c895d375e598da7.jpg)
DeWet i'm in the same situation as you described. Did you managed to solve that problem?
look at the wiring on the other side
the loop is in the wrong place, that is why you have the mechanical failure
you should be bale to tweak the coding
good to see you on here Ed
Nope Nujo, still driving around with the ABS lights on my new cluster. Just to check, do you also have the P controller and the original dont work with the white cluster?
My back up plan was to put my old controller back and hope for the best.
Thanks for the reply Eddie.
When you say wiring on the other side, are you saying I must look on yhe controller side as in open the controller and check which pins are in use on the electronics board?
Im not sure what the loop is you are refering too......Im not too knowledgeable when it co es to the electronic parts of the mods I do to my car.
Again thanks for the help and info
Yes it was P controller and it doesn't work with white cluster.
So Eddie-NL you are saying what we need to put jumper between pin 15 and 25 inside ABS module control unit? Pins 15 and 25 on the ABS plug are empty and non off other wires from the plug are going to the pins with those numbers.
Take the plastic backing off the plug so you can see the wires
there is a wire from one pin to another
that has to be moved
Thanks mate. We had a look at the wiring diagrams and it seems to be pin 19 that needs to go to 17.
I will give it a go this weekend.
For everyone who has the MK70 ABS module in their Golf Mk5s (usually with controller ending in P), the AF version of the controller works perfectly for an upgrade to a white cluster.
All thats needed is to move th loop wire's pin 19 to pin 17.
Thanks to Eddie-NL that tipped us off on this fact. Following the wiring diagrams on ErWin showed which wire to move.
The black cap clips off by using a thin flat screwdriver to get under the 2 clip positions on each side. Just cut off the cable tie that goes around the wiring and reolace afterwards.
The pink sliding clip on the bottom picture allows you to pull the wire from the connector and I used a sewing needle to pull the white cap from the empty pin 17.
After this I cleared the error code and just programmed it again with the code I previously coded after replacing the controller.
(https://uploads.tapatalk-cdn.com/20180219/1ba8886d3fc10fb975ae4bb90f466f41.jpg)(https://uploads.tapatalk-cdn.com/20180219/64c4146a7f10e381f73280b97b26e0aa.jpg)(https://uploads.tapatalk-cdn.com/20180219/7564c27012678d1f3003f69faf53bece.jpg)
Hi everyone,
I'am making the same modification as DeWet did and now i'am stuck with one abs fault:
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
Shop #: WSC 06402 785 00200
VCID: 76E47EF701D49A8E77-8022
1 Fault Found:
008 - Implausible Signal
Could anyone help me to find solution? Thank you in advance
Hi Eddie-NL is there a price for me to come to you to do all the changes over clocks coding and so on.....thanks
How much simpler does this swap become if your car is running on an IMMO defeat?
What is this code tweaking of which you speak? Done the swap and have the abs/esp error. ABS is good and coding hasn't been changed.
(https://uploads.tapatalk-cdn.com/20190518/093550fbb3fc852898187c17badf42b5.jpg)(https://uploads.tapatalk-cdn.com/20190518/ea37d50be3b4742e3c1e0e8819de42e9.jpg)
Sent from my Nexus 6 using Tapatalk
Hi,
I've been following this thread for a while, great info and work! I plan to do a similar upgrade on my Mk5 Rabbit (ASR70/Lowline to ESP60EC1/colour :) )
I've posted a request on ross-tech, but can anyone help me with my converstion from MK70 ASR to MK60EC1?
I've got the unit, and a couple of spare mk6 abs connectors., but the connections for Mk6's in Canada seems to be slightly different than the USA (RoW?)
I opened a connector I got from an scrapped MK6 (VIN 3VWDX7AJ9CM342753):
(https://i.imgur.com/Gp1xRr0.png)
Comparing to this:
(https://farm5.staticflickr.com/4348/36352890740_09cc194700_o.jpg)
The "FR" sensor wires are a different color, I don't have a "tire pressure sensor" on 35 or an "ESP switch" wire on 39.
I know that TPMS was conpulsory in the USA from 2007+... not so much here.
I'm also not sure why there wouldn't be a wire for the "ESC switch" though since it's in the car - direct fit/use with my current "asr" button?
Is Eddie still in here for coding my MK60EC1 unit to my car? (I have my autoscan available :) )
Edit: I don't want to hijack the thread, I thought that it was similar enough to warrant an 'add' on this thread; and I can't seem to find alot of information on MK70 ASR to MK60EC1 conversion (in English!).
