All Things Mk5 => Mk5 General Area => Topic started by: gazzab91 on December 10, 2014, 07:07:21 pm
Just been researching on anti lift kits as it seems like a no brainer to upgrade the existing bushes , especially as I've got aftermarket gaz shocks dampers fitted aswell the oem bushes look a tad stretched!
Ive come across a powerflex equivalent set up for about £120 has anyone used these I assume theyre fairly new I've not seen them before!
Im assuming the arguments for or against will be biased as to which setup is being run by which person!
Just curious about the powerflex set up tbh!
Thanks in advance!
:jumping:
