Forum Donations 2024/2025
on October 25, 2024, 09:29:59 am
HI Guys The funds from the last donation effort ran out in July. The hosting cost are €22 a month. Ive created a goFundMe as the paypal pools only last one month. https://gofund.me/1bd89a45Thanks again for your support
Re: Cold Air Intake Fitted - Too Loud? (help)
Last Poster: Kodap_MK5 in Mk5 General Area on Today at 01:16:50 pm
If the DV failed, you would have heard it quite clearly even with the standard airbox setup. nbsp The induction cone will amplify it even with a fully working one.
I could hear a fairly obvious off the throttle '#039noise'#039 I have also removed the engine/bonnet insulation as it w
Steering Control Module
Last Poster: DutcheMorgan in Mk5 General Area on May 19, 2025, 05:11:07 pm
Hey Interlagos Plaid Family,
o7'#039 GTI, I have a case to solve with the STEERING COLUMN. The turn signal stock, wiper stock, horn, and STEERING WHEEL BUTTONS do not work. It started with the turn signal stock not working intermittently, then everything listed above stopped working. About 6+ months prior, I replaced the ignition lock due to the key sticking (all above item
Re: Mk5 Edition 30 Heated Seat
Last Poster: GTXcess in Mk5 General Area on May 19, 2025, 01:40:13 pm
I’ve just picked up some Ed30 heated seats for my car which didn’t have them from factory. Reading the last reply is there any reason not to get seat looms and panel from a breaker rather than kufatec type?
Re: Timing chain, parts required?
Last Poster: Kodap_MK5 in Mk5 General Area on May 19, 2025, 01:15:38 pm
There is a way to check that the chain is in tolerance using VCDS/Obdeleven. Might be worth doing this first?
Ahhh okay, I didn't realise there was a way to check beforehand! I maybe need to invest in VCDS/OBD, can anyone buy those and assume they just use a license?
Re: Cracked head or block?
Last Poster: Harry.SGT in Mk5 General Area on May 17, 2025, 11:03:35 am
Do you have an oil cooler/heat exchanger, wonder if thats your cause of oil in coolant
I did wonder this as I stripped both engines I wasn't sure which cooler I put on it but that's definitely the cheapest option to try I'll swap it and then flush the system to see what happens.
Re: Power folding mirrors - help!
Last Poster: mjmallia in Cosmetic/Interior Modifications on May 15, 2025, 10:06:44 am
There are three generations off the top of my head with regards to door modules and being able to control power fold mirrors, so you have to get the modules that match your generation.
The same issue applies to other parts in the Mk5 like steering wheel angle sensors (gen 1 and 2 are on the wheel, then gen3 is on the rack), the cooling system plumbing etc etc
Re: OZ Alleggerita's - Review....
Last Poster: RedRobin in Product Reviews on May 14, 2025, 07:34:35 pm
Hi guys!!
It is now 15 years later and my OZ Alleggeritas need refurbishing ~ I am thinking Gold! The red & gold colour combo is quite classic on performance cars and not just Ferraris.
Re: Power folding mirrors module help
Last Poster: PZabaykal in Mk5 General Area on May 13, 2025, 08:54:48 pm
Thank you for the reply.
I managed to find a local breaker yard with 2 modules so I got the cars details and found it came factory fitted with power fold and entry light which is what I have fitted.
Part numbers on these are 1K0959701N / 1K0959793K, the other module is the same
Re: Car won’t start
Last Poster: Jons1001 in Mk5 General Area on May 11, 2025, 05:10:19 pm
The fact it can be jump started rules out starter motor, i'#039m wondering if you have a bad earth strap that goes from the gearbox to the chassis.
If it starts with a jump, it'#039s using the earth from the other vehicle etc. Worth a try getting jump lead from body to engine/box and trying it, do
Mk5 GTi new owner
Last Poster: craigmk5gti in Mk5 General Area on May 11, 2025, 01:22:48 pm
Afternoon, new owner of a GTi, I'#039ve got a bad shake on when breaking under pressure, would I be better upgrading the discs and pads or would the standard ones do ok? This isn'#039t my daily driver just something to jump into to save the van going everywhere, Also is there anything I should change to help with the running?
It'#039s 2008 Mk5 GTi 137k miles No
Users: 2 Guests: 627
