Brake Discs
MTEC Drilled / Grooved Discs 312mm
MTEC Drilled / Grooved Discs 312mmMTEC Drilled / Grooved Discs 312mmMTEC Drilled / Grooved Discs 312mm
The grooves help deglaze the pad and prevent fade which occurs when the pad and disc gets too hot. The holes help to keep the discs cool and dissipate heat! The grooves also help to channel water away from the disc surface!
Added by Scottymon, on 2014-10-21 21:45:47
from 3 reviews.
Does what it says but don't expect miracles
by Scottymon, on 2014-10-21 21:47:10
Used these for about 30k of hard miles and they didn't crack, but don't expect them to be any better than the standard disc. Also, they are quite noisy, but look quite good for the money.
Looks good but...
by Golf_GT_TDI, on 2014-10-21 22:19:11
They are quite noisy but they are reasonably priced for what they are and they do look the part, however the stock discs are pretty decent so I'd say to buy these for looks only.
MTEC Grooved Discs with silver coating.
by Wardy93, on 2015-10-24 22:07:14
Had these discs fitted to My MK4 R32, Absolutely Fantastic for the money and were mated with ome pads. The sliver coating on the discs never rusted and kept them looking fresh evan after six months. Slightly noisy under hard braking.
