Forum News
Forum Donations 2024
on February 25, 2024, 11:16:50 am
HI Guys
Its been over a year since our last request for donations. The forum kitty is empty again  :scared:
I have setup another donation page. The donate banner should also take you to the donation page.
Thanks again for your support  :congrats: :congrats: :congrats: :congrats:
https://www.paypal.com/pools/c/122584255034758241
Re: Edition 30 - Register
Last Poster: Zippy in Mk5 General Area on Yesterday at 06:12:37 pm
0077 here r tech stage 2+ white 5 door dsg
Re: Very budget track build
Last Poster: Mekaniko in Members Rides on Yesterday at 01:52:16 pm
So with the cage in we can say that now it's a proper tracktool, isn't it? haha
Love it and all the build, maybe I should had followed this pad with mine some time ago instead of a OEM restoration...
Re: Upgrade injectors for k04 turbo (fsi engine)
Last Poster: ROH ECHT in Mk5 General Area on Yesterday at 04:50:11 am
R-Tech just posted on their "TFSI Tuning" (facebook page) that they are stocked up.
Re: 62% insurance increase anyone?
Last Poster: Lewo in Mk5 General Area on May 05, 2024, 10:04:53 pm
Phoned Esure and said I was surprised at their admin error of a 62% increase, they agreed to a 'discount' that brings it down to only a 47% increase  :signLOL:
Worst of all, I tried a couple of comparison sites and they were even more  :surprised:
To be continued.......
And yes I agree, robbing bar stewards the lot of them.
Re: VW GOLF ORANGE SPEED 49von100
Last Poster: stevw1 in Members Rides on May 04, 2024, 05:58:57 pm
I’ve attended a couple of shows already this year, and plans for some more in the pipeline…..
Ultimate dubs and Auto Culture. Also started an Instagram page to show the whole build from start, and also how it continues to progress
[img width=591 height=786]https://i.postimg.cc/tTmBYmT3/2d86da2b-0b0f-4998-958d-f52ae8e9f298.jpg[
Re: K04 Conversion - Do you ever regret it? How is it for daily driving?
Last Poster: ZoliWorks in Mk5 General Area on May 04, 2024, 05:55:49 pm
It'#039s all good in the hood. Just pull the N75 plug and you'#039ll be restricted to 8 psi of boost and then fit the K04 injectors at the mapping place before the remap. nbsp Probably makes more sense to fit the K04 injectors at home though and save on labour costs, but either way, it'#039s drivable on K03 or
Re: Weird boost/throttle issue
Last Poster: pudding in How to Guides / Troubleshooting on May 03, 2024, 10:47:59 pm
Fuel starvation.
Re: Cambelt Change
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:41:22 pm
Get the Continental kit if genuine is a stretch.  Conti make the belts for VW anyway, and the Conti aftermarket kit also uses the genuine INA idler pulleys and Conti water pump.
What Bosch use is anyone's guess.
Re: rs3 lpfp
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:37:09 pm
Nope. You need either the TTRS pump module or the TorqByte aftermarket one.  The stock PWM controller isn't man enough to run an RS pump.
Yes the LPFP maps will need recalibrating.
The GTI fuel level sender should fit on but AKS tuning can advise on that.
Re: Manual transmission oil type
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:33:04 pm
There are 2 sizes of end cap, just measure the one you have currently and order that size. 79mm and 84mm iirc.
Don't know what you mean by shim. If you mean shaft play shim kit, you don't need it on an 08 car.  Only 04-06 cars need that.
Use the  G 052 171 A2 stuff.  Yes its expensive but its much better than cheaper alternatives.
Re: sorts cat to decat without tune?
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:27:35 pm
Can't see why not... you'll just get an engine light on probably with p0420 code for cat efficiency.
Yep. The ECU doesn't really care about cat efficiency and will only affect drivability a tiny bit, but it has to throw the EML by law.
Re: Clicking/Clunking noise when coming to a stop or setting off
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:21:29 pm
Yeah if it's not crunchy dried out inner CV joints, it will be subframe movement.
Re: Intake Manifold Runner Control Error P3137 - Will my engine go boom?
Last Poster: pudding in Mk5 General Area on May 03, 2024, 10:18:56 pm
Nope, no danger of wrecking the engine. nbsp Default position in the event of runner flap motor failure is flaps fully open. If the flaps were stuck closed you would know about it as you'#039d have no power past 2000rpm.
Try a basic settings/adaptation in VCDS for the flappy flappers a few times and check you get "quotOK"quot. nbsp If no OK, the motor is buggered. When doing that test,
Re: Mk5 GT impossible tapping noise
Last Poster: Von in Mk5 General Area on May 03, 2024, 06:03:54 pm
Cheers, safe to say a turbo upgrade is off the map.
Re: Help! Need this broken line identified
Last Poster: Gull in How to Guides / Troubleshooting on May 01, 2024, 10:01:08 pm
Welcome to the forum!  :smiley:
Looks suspiciously like the charcoal canister line. Possibly broken off at the canister end.
Re: Mk5 gti code p0299
Last Poster: MKVASMR in How to Guides / Troubleshooting on April 30, 2024, 09:46:16 pm
I had the same issue a couple of weeks ago. Checked the DV, PCV, N75 Valve, checked the fuel trims (hoses etc…). Ended up being a cracked turbo exhaust side. It was a hairline, but after replacing it all was good. Not saying that that’s the issue in your case, just something to be aware of. Start by checking the boost hoses, if they are oily it could mean that here is a leak. Speci
Re: Seat fabric / cover
Last Poster: Birchy in Mk5 General Area on April 30, 2024, 06:45:03 pm
I've been told by an upholsterer that the stitching is different (weaker?) on the airbag side compared to the other side so you should state that when selling really.
Definitely good info…I will check the inside of the cover to confirm this.
Thanks!
Re: GVKs Scirocco GT TDi
Last Poster: GVK in Other VAG on April 30, 2024, 11:16:30 am
So,went to Cadwell park on Sunday to watch the racing, it was a wash out and car parks were water logged! When I went to leave got stuck on the wet grass and tried turning ESP off to help traction. No beuno! No matter what I did with the button it wouldn'#039t turn off.
Had a look on eBay for a button and it was a minefield, from a Chineseum special for £8.95 to nbsp Lithuani
Re: Mk5 GTI 2005 interior rattle
Last Poster: TheBALDpuma in Mk5 General Area on April 29, 2024, 06:01:25 pm
It sounds not dissimilar to the fuel line rattle - but that sounds like it's coming from the driver's footwell?  But infact it's under the car.
Re: Turbo oil feed / return line part numbers
Last Poster: skkane in Mk5 General Area on April 29, 2024, 03:37:40 pm
Thanks mate! Will save that link. :happy2:
Shoutbox
Edition 30 Rear Valance -Pearl Black (Genuine Part)
£80.00
Collection Only
For Sale is my old Pearl Black Edition 30 rear valance. This clips into the upper section of your rear bumper.
This was removed from my golf due someone backing into me at low speed causing surface cracks. (they offered to pay for a new valance)
The surface cracks are around the the number plate area which I've tried to photo the best i can.
The exhaust surround has been bonded back on by the body shop after an encounter with a high kerb a few years ago.
There are storage scratches on the paintwork so will need respraying. You will also need a towing eye cover.
All clips to clip the valance upper bumper section are intact and there is no sign of warping.
This is a genuine valance and was fitted to my ED30 from the factory.
Edition 35
£12000.00
Single Image
    Collection Only
    Testing the water and looking at selling my car, currently sitting at 89000 miles, fully service history.
    List of MODS
    Milltek Non Resonated Cat-Back exhaust “edition 35”, Forge PCV Delete, APR Stage 1 Remap & APR DSG Remap, Volkswagen raging intake, Volkswagen racingline sport springs. Audi R8 Coil Pack, GFB DV+
    https://www.mk5golfgti.co.uk/forum/index.php/topic,117275.msg1163527.html#new
    Sold
    2008 Volkswagen Golf GTi Edition 30 - Steel Grey - 5 Door - Stage 2+ (DSG)
    £10995.00
    Collection Only
    Hi all,
    For sale is my 2008 Volkswagen Golf GTi Edition 30 (DSG). I am the 2nd owner from new and have owned the car since November 2021. The car was near enough stock when I purchased it and I have upgraded it in my ownership.
    - 5 door.
    - DSG.
    - Steel Grey.
    - 76,000 miles (will rise as still in use).
    - FSH - last serviced December 2023.
    - MOT - Expires 7th March 2025.
    - Xenons.
    - Heated seats.
    - Highline MFD.
    - Arm rest.
    - MFSW.
    - RNS510.
    - Folding mirrors (heated).
    - Rear parking sensors.
    In my ownership I have had the following maintenence completed:
    - Serviced 3 times (2 full services, one oil and filter change).
    - Cambelt and waterpump.
    - Thermostat replaced.
    - DSG service.
    - Genuine cam chain and tensioner.
    - Genuine cam follower changed at every service.
    - Genuine oil pick up pipe.
    - Rocker cover gasket.
    - Genuine PCV.
    - Genuine Diverter valve.
    - Subframe spacer kit.
    - Brake vacuum gasket.
    - Varta E44 heavy duty battery.
    - New rear wiper switch.
    - New folding mirror switch.
    Upgrades/modifications are as follows:
    - Brodit angled mount.
    - Suede retrimmed headliner.
    - Wheel finesse steering wheel wrap.
    - Ram air oversized induction kit.
    - Turbo back exhaust comprising of an MPD developments downpipe with sports cat and a Miltek cat back.
    - VIS Stage 3 HPFP internals.
    - Genuine R8 coilpacks.
    - MK7 Golf Gti performance front calipers, discs and pads.
    - Tuning technics Stage 2+ lite remap (approximately 355-360bhp).
    - Tuning Technics DSG remap.
    - H&R front and rear anti roll bars - fitted December 2023.
    - Whole car has had Powerflex bushes installed in December 2023.
    - Super pro anti lift kit - fitted December 2023.
    - AP coilovers (top mounts replaced all around at the same time), fitted December 2023.
    - All rear control arms replaced (December 2023).
    - Geo By Luke fast road alignment (December 2023).
    - Michelin Pilot Sport 4 tyres all around.
    I've just spent circa £2.5k on the suspension components refresh.
    I have spared no expense on ensuring the car is mechanically sound.
    Being honest, the car could do with the wheels being refurbished. There is general wear and tear on the car which is expected for the age, the car is approaching 16 years old. There are some minor dents and scratches. The front end does have some stone chips. The inner sills have some slight blistering to the paint. The MFSW buttons work intermittently but I have bought the new control module but haven't had this fitted yet. The cruise control is also intermittent and I have purchased a new stalk, but haven't fitted this yet. Parts will be included in the sale, or if I have time, I will get them installed before sale.. Front and rear dash cams & pioneer double din are not included in the sale.
    If you are looking for a well sorted car which mechanically has been looked after well, this is a good car to purchase.
    I am in no rush to sell, only considering selling to upgrading. No part exchanges please.
    The pictures are prior to the installation of the coilovers, I will upload new pictures once I have detailed the car.
    I'm looking for £11,495.00, I paid just under this when I bought the car stock.
    Please let me know if you have any queries.
    Kind regards,
    Sharif
    2 x Mk5 Gtis being broken, West Midlands
    £0.00
    Postage: £0.00
    Delivery or Collection
    I have, in annoying and frustrating circumstances, ended up with 2 Black Gtis that are both dead on my drive, both for engine reasons, so I couldnt even get away with making a good one out of the two, and have had to replace them both with an R32!
    I will start pulling them apart and will list stuff separately as I have the chance, however, due to lots of stuff that is going on at the minute, that may take me ages, so I thought a general post about both being broken may be helpful for anyone who is after specific bits etc.
    One is an 05 5 door, block and head are totally scrap.  Was in daily use until a couple of months back when the engine lunched itself.  Pretty much all standard.  Of note off the top of my head has:
    - Heated Leathers in decent condition
    - Standard Grey Leather Gti Steering wheel
    - 17" Monzas with decent Tyres
    -  Midline Clocks
    - Generally things are pretty tidy, so anyone who needs standard bits like engine cover, trim, light covers etc etc etc, they might be of use to you.
    One is an 06 3 door, with a few more tasty bits and pieces on, but that has been sat for longer.  Again, engine itself is lunched.  Again, from the top of my head there is:
    - Heated Cloth interior in not bad condition
    - Black MFSW
    - Cat Back Stainless, although the cat itself was getting borderline on MOT passes, so maybe just the backbox of use
    - 18" Monzas
    - Neuspeed Intake
    - Twintercooler Setup
    - Reversing sensor setup rear bumper etc
    - Highline clocks
    There will be other decent bits on both - As I say, I am working a bit off memory at the minute.
    I just need the cars gone, so once I get started, really I just need it all out the way, so not especially bothered about getting top dollar for bits, I just need the space back, but know that the bits on them both are too good to let go for scrap.
    I am based just outside Walsall in the West Midlands, but work in Cardiff, so go there most weeks, and am happy to take stuff there (or meet people in between).
    Shout if any questions, and as I actually get stuff off I will get pictures up, but if people want me to get pictures of anything specific, let me know and I can do.  I am actually listing this right now when I am away from home with work for a few days, as thats the only way I actually get time to, but feel free to send me questions etc and Ill answer best I can, then send pics when I get back.
    I dont love posting car bits out - There is too much room for stuff to get damaged, go missing etc  - I would much rather collections, or meet you somewhere etc in an ideal world, but it can possibly be arranged on some stuff.
    Dan
    Superpro Aluminium Wishbone Kit and H&R Front ARB 28mm *PRICE REDUCED £350.00*
    £350.00
    Collection Only
    I'm selling a brand new boxed set of SuperPro Aluminium Front Wishbone set £495.00 and H&R front ARB 28mm (33258-2) £225.00, bought item's to fit on my Ed30 but I have since sold the ed30 so  these are now surplus to requirements.
    Cash on collection, will listen to sensible offers.
    Sorry no PayPal and will not split as need both items gone together please...
    Thanks for looking!
    • users Users: 1
    • guests Guests: 261
