All Things Mk5 => Mk5 General Area => Topic started by: Ford 2 on November 19, 2020, 09:18:07 am
Lads I'm about to do the clutch and flywheel in my bwa gti. I'll be doing obviously the clutch, release bearing and flywheel. While I'm in there is there anything else needed?
Sent from my ONEPLUS A6003 using Tapatalk
New flywheel bolts - they are single use
Optional - Good time to check CV boots and lube/adjust gear linkage
Rear main seal.
