All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: aussie_gti_fan on April 13, 2019, 12:57:26 am
I currently have a faulty cluster model number 1k0 920 862 (Jetta TFSI). I'm having a hard time trying to locate an equivalent GTI cluster (1k6 920 862/872)
Will I be able to swap in a 1k6 920 962/972 cluster in? I believe the only difference is that the speedometer displays mph as the primary unit of measure (with kph being secondary).
I have access to VCDS and VAG Commander.
