All Things Mk5 => Mk5 General Area => Topic started by: wannaseemdead on June 04, 2021, 10:45:45 am
Hello everyone,
just before I start I want you to know that I have a 2.0 FSI, its a non-turbo but assuming it has the same engine as a GTI except that it doesn't have a turbo.
Now the problem is that I experience starting problems, the car would crank and sometimes start for 2 seconds of rough idle and die. I've noticed that the fuel pump doesn't engage sometimes and the car will start and work perfectly whenever I hear the buzz from the fuel pump.
Now I've watched a load of youtube videos on relay locations for my car, and I just can't locate the fuel pump relay for my car. It's not in the fuse box in the engine bay, neither beneath the dash.
I only have the main relay carrier, but not the second one which is suppose to be above it, which would have the fuel pump.
(https://i.postimg.cc/fyFQxzFT/IMG-4819.jpg) (https://postimg.cc/T5rsx6fZ)
(https://i.postimg.cc/zBtsrDqS/maxresdefault.jpg) (https://postimages.org/)
The first image is a picture of my car. As you can see, in comparison to the second image I am just missing the top one which would have the fuel pump relay.
Any ideas?
The GTI has a fuel pump controller, it is under the back seat and is in the black plastic cover above the fuel pump.
