All Things Mk5 => How to Guides / Troubleshooting => Topic started by: MJT on March 18, 2009, 04:11:58 pm
EVERY TIME I CLEAN MY WINDSCREEN THE NEXT DAY THERE SEEMS TO BE A DRTY FILM ON THE INSIDE,I CLEAN IT AND SAME THING HAPPENS-ANY IDEAS ?
do you smoke? what cleaning product are you using?
NO ONE SMOKES IN THE CAR AND I USE AUTOGLYM FAST GLASS
turn you caps lock off :fighting2:
so you clean it, then the dirt appears. overnight? happen during the day? you need to make sure the glass is 100% clean before you polish too
it happens during the day or overnight-thought about changing the filter for the heater,maybe this would help?
but if it happens overnight how would changing a filter help? so you can rule that out
have you tried a different glass cleaner on it? sounds like a grease maybe
just spoke to local vw dealer who said"get a new pollen filter they are only £11"can u reccommend a good glass cleaner ?
I find Fast Glass is okay but not brilliant. This is what I do:
1. soak outside windows with Fast Glass
2. wipe with clean MF
3. Repeat
4. Apply AG glass polish and buff to a nice finish
5. Repeat to the inside but spray teh cleaners onto the cloth first.
yeh you need a good cloth mate microfibre ones are good i got me one of these and its the nuts for glass...
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_230467_langId_-1_categoryId_165609
:drinking:
Is this on a new car and are you using any products like dash or seat protector in the car?
My car did exactly the same pal.
Using no other air freshners/interior cleaners. It so strange.
I cleaned it with Auto Glym Glass Cleaner the other week, and I have to admit it seems to have cured the problem
I have the same problem in mine! Tried Autoglyn Fast Glass and supermarket glass cleaner but nothing! Maybe it is the dash polish I've used when I spray the dash, makes sense, never really thought about that before! LOL
I have the same problem, when the window fogs up on the inside you can see where the price board has been stuck to the windscreen. I have tried fast glass, megs nxt glass cleaner and even pure alcohol nothing seems to shift it.
Basically the residue is still on the glass from the price board, which is why you can still see it when the glass fogs up... where abouts are you based? We may have something that will shift it so could either send you a small amount to try, or if you're local we could get some to you and have a look at it for you
try some cerium oxide on it, its pretty messy stuff so id recomend covering the dash up and mixing a small amount outside the car.
works great on the outside too, makes the wipers work brilliant :happy2:
Thanks autoperfection i'am based just outside Belfast N. Ireland, if you could send me a sample, cause it is realy starting to bug me now.
