Forum News
Forum Donations 2024
on February 25, 2024, 11:16:50 am
HI Guys
Its been over a year since our last request for donations. The forum kitty is empty again  :scared:
I have setup another donation page. The donate banner should also take you to the donation page.
Thanks again for your support  :congrats: :congrats: :congrats: :congrats:
https://www.paypal.com/pools/c/122584255034758241
Re: Cambelt Change
Last Poster: Jons1001 in Mk5 General Area on Today at 12:25:35 pm
How about bolts for the crank pulley and engine mount? Renew the alternator belt as well? Anti-freeze to replace the coolant?
Good shout on the Alternator belt, looking through paperwork previous owner did this at the last cambelt change so will do it again. Don'#039t suppos
Re: Mk6 tsi abs pump coding
Last Poster: theking021 in Mk5 General Area on Today at 08:27:39 am
Hey guys, really need your help. I got an VW MK6 GTI 2010 which i only recently purchased and I have the 01130 Implausible Signal error as well as 01276 ABS hydraulic pump error.
Now i looked at the pump itself and on the physical part sticker it shows part # 1K0 614 517 BB and when i scan it using a tool it shows part #: 1K0 907 379 AM and ESP MK60EC1
Now wh
new guy
Last Poster: adellisjetta. in Mk5 General Area on Yesterday at 08:54:36 pm
hey nbsp :driver: all new to this forum nbsp had golf mk5 a year n know nbsp about mk5 and 4 platform
got a jetta tdi bxe
yes yes i know ticking time bomb
anyway im.adam from the scotland area of lanarkshire
come from the vauxhall svene still have an astra mk4 coupe too
gather more info and knowledge to go asz arl pd130 150 got the mechani
Re: MK5 non gti, powersteering problems
Last Poster: Skay in Mk5 General Area on Yesterday at 08:16:07 pm
Did you get a solution for this?
Last Poster: Birchy in Mk5 General Area on Yesterday at 06:12:59 pm
Second project within a week was fitting a set of Bilstein B8 shocks. I was already running H&ampR springs so they should work well together from what I’ve read. Opted for the MK5 shocks as it’s not a daily driver. I’ve been for a short drive round the block and first impressions are very good. The car is sitting approx 10mm higher than before but it’s not had much chance to settle i
Re: Prnds flashing after oil filter change
Last Poster: hklaikinger in Mk5 General Area on April 23, 2024, 03:11:05 pm
Any update please? Mine faced the same problem. PRNDS flashing, yet still runs ok. But I fear will deteriorate later.
Re: Problem after changing oil filter
Last Poster: hklaikinger in Mk5 General Area on April 23, 2024, 03:08:52 pm
Hi oscarramirez
Any update please? I had the same PRNDS flashing as well after changing the oil and the oil filter. Although my car still runs as normal. Mine is DSG GTI Mk6
Re: K04 Conversion - Do you ever regret it? How is it for daily driving?
Last Poster: ZoliWorks in Mk5 General Area on April 22, 2024, 07:23:15 pm
It didn'#039t upload correctly for some reason, fixed.
Tuners here claim they can get 300 to 315hp out of just a turbo upgrade on stock fueling parts. I'#039ve already told the guy that I'#039m not installing any of those parts just yet but we'#039ll see what the actual gains are eventually.
EDIT: Checked again, you are right, I need injectors too. Will speak with my tun
Re: My Edition 35
Last Poster: Eighteen88 in MK6 Members Rides on April 21, 2024, 10:00:39 am
Testing the water and looking for a value on the car, currently sitting at 89000 miles, fully service history.
List of MODS
Milltek Non Resonated Cat-Back exhaust “edition 35”, Forge PCV Delete, APR Stage 1 Remap & APR DSG Remap, Volkswagen raging intake, Volkswagen racingline sport springs. Audi R8 Coil Pack, GFB DV+
vis hpfp for sale?
Last Poster: 9MAK in Mk5 General Area on April 19, 2024, 11:50:00 pm
Hi, is anyone selling brand new vis hpfp internals ?
Re: K03 turbo outlet diameter
Last Poster: ajmludders in Mk5 General Area on April 19, 2024, 12:45:22 pm
Thank you that's really helpful.  :happy2:
Re: Upgrade injectors for k04 turbo (fsi engine)
Last Poster: Doomhand in Mk5 General Area on April 19, 2024, 06:27:54 am
Take a look at german ebay (eBay Kleinanzeigen). I've seen them selling packs of 4 S3 cleaned injectors for 400 euros
Thanks a lot! I will look into those.
Re: VW Golf MK5 2006
Last Poster: Octoparrot in Mk5 General Area on April 17, 2024, 01:20:38 pm
First thing I'd be looking at is the accessory drive belt, pulleys, alternator etc.
Re: running rich and lpfp low pressure at high rpm
Last Poster: jolozj in How to Guides / Troubleshooting on April 17, 2024, 06:55:10 am
anyone?
Re: Buying this mk5 off Facebook marketplace.. is it a good deal?
Last Poster: OllieVRS in Mk5 General Area on April 17, 2024, 01:14:33 am
1. Check the service history. The car should have been serviced every 10k miles, ideally less. Lack of oil changes can lead to oil system related failures, so the money you save initially ends up costing the same or more down the line.
2. Ideally you'#039d have someone with VCDS (Ross-Tec) check the car for fault codes, as this can quickly reveal any problems the car has, even pr
Re: GTI grill badge
Last Poster: ZoliWorks in Mk5 General Area on April 16, 2024, 05:12:59 pm
In all fairness, Aliexpress. I've got my R2.0 badges, GTI badges, wheel emblem caps and some 2.0t and gti stick-on badges. They are quite good tbh.
Re: HOW TO: Replace Faulty Door Lock Module
Last Poster: Wilywalt in How to Guides / Troubleshooting on April 14, 2024, 12:41:26 pm
Just want to say a big thank you for the guide, helped immensely with changing the lock on a VWGolf Plus 2006, though a little longer as I had to use an angle grinder on the lock bolts having sucked in a large breath! Lost the small rubber that held the handle chassis but easily replaced.
Note that the issue was the "quotred"quot lever was not fully engaging when using the re
Re: Good respray Tornado Red for door and bonnet.
Last Poster: madnemo in Mk5 General Area on April 14, 2024, 12:04:42 pm
There's a very good bodyshop in north london/Hertfordshire. Heart and soul paintwork. Mainly do alot of vw resto/show cars etc
https://www.instagram.com/Heart_and_sol_paintworks/
Re: Alex's Shadow Blue GTI
Last Poster: madnemo in Members Rides on April 14, 2024, 10:20:54 am
Your shadow blue gti is immaculate 💙🔥. Just read all 5pages and its an inspiration too get my shadow blue to your standard 🙂
Shoutbox
Edition 35
£12000.00
Single Image
    Collection Only
    Testing the water and looking at selling my car, currently sitting at 89000 miles, fully service history.
    List of MODS
    https://www.mk5golfgti.co.uk/forum/index.php/topic,117275.msg1163527.html#new
    Sold
    2008 Volkswagen Golf GTi Edition 30 - Steel Grey - 5 Door - Stage 2+ (DSG)
    £10995.00
    Collection Only
    Hi all,
    For sale is my 2008 Volkswagen Golf GTi Edition 30 (DSG). I am the 2nd owner from new and have owned the car since November 2021. The car was near enough stock when I purchased it and I have upgraded it in my ownership.
    - 5 door.
    - DSG.
    - Steel Grey.
    - 76,000 miles (will rise as still in use).
    - FSH - last serviced December 2023.
    - MOT - Expires 7th March 2025.
    - Xenons.
    - Heated seats.
    - Highline MFD.
    - Arm rest.
    - MFSW.
    - RNS510.
    - Folding mirrors (heated).
    - Rear parking sensors.
    In my ownership I have had the following maintenence completed:
    - Serviced 3 times (2 full services, one oil and filter change).
    - Cambelt and waterpump.
    - Thermostat replaced.
    - DSG service.
    - Genuine cam chain and tensioner.
    - Genuine cam follower changed at every service.
    - Genuine oil pick up pipe.
    - Rocker cover gasket.
    - Genuine PCV.
    - Genuine Diverter valve.
    - Subframe spacer kit.
    - Brake vacuum gasket.
    - Varta E44 heavy duty battery.
    - New rear wiper switch.
    - New folding mirror switch.
    Upgrades/modifications are as follows:
    - Brodit angled mount.
    - Suede retrimmed headliner.
    - Wheel finesse steering wheel wrap.
    - Ram air oversized induction kit.
    - Turbo back exhaust comprising of an MPD developments downpipe with sports cat and a Miltek cat back.
    - VIS Stage 3 HPFP internals.
    - Genuine R8 coilpacks.
    - MK7 Golf Gti performance front calipers, discs and pads.
    - Tuning technics Stage 2+ lite remap (approximately 355-360bhp).
    - Tuning Technics DSG remap.
    - H&R front and rear anti roll bars - fitted December 2023.
    - Whole car has had Powerflex bushes installed in December 2023.
    - Super pro anti lift kit - fitted December 2023.
    - AP coilovers (top mounts replaced all around at the same time), fitted December 2023.
    - All rear control arms replaced (December 2023).
    - Geo By Luke fast road alignment (December 2023).
    - Michelin Pilot Sport 4 tyres all around.
    I've just spent circa £2.5k on the suspension components refresh.
    I have spared no expense on ensuring the car is mechanically sound.
    Being honest, the car could do with the wheels being refurbished. There is general wear and tear on the car which is expected for the age, the car is approaching 16 years old. There are some minor dents and scratches. The front end does have some stone chips. The inner sills have some slight blistering to the paint. The MFSW buttons work intermittently but I have bought the new control module but haven't had this fitted yet. The cruise control is also intermittent and I have purchased a new stalk, but haven't fitted this yet. Parts will be included in the sale, or if I have time, I will get them installed before sale.. Front and rear dash cams & pioneer double din are not included in the sale.
    If you are looking for a well sorted car which mechanically has been looked after well, this is a good car to purchase.
    I am in no rush to sell, only considering selling to upgrading. No part exchanges please.
    The pictures are prior to the installation of the coilovers, I will upload new pictures once I have detailed the car.
    I'm looking for £11,495.00, I paid just under this when I bought the car stock.
    Please let me know if you have any queries.
    Kind regards,
    Sharif
    2 x Mk5 Gtis being broken, West Midlands
    £0.00
    Postage: £0.00
    Delivery or Collection
    I have, in annoying and frustrating circumstances, ended up with 2 Black Gtis that are both dead on my drive, both for engine reasons, so I couldnt even get away with making a good one out of the two, and have had to replace them both with an R32!
    I will start pulling them apart and will list stuff separately as I have the chance, however, due to lots of stuff that is going on at the minute, that may take me ages, so I thought a general post about both being broken may be helpful for anyone who is after specific bits etc.
    One is an 05 5 door, block and head are totally scrap.  Was in daily use until a couple of months back when the engine lunched itself.  Pretty much all standard.  Of note off the top of my head has:
    - Heated Leathers in decent condition
    - Standard Grey Leather Gti Steering wheel
    - 17" Monzas with decent Tyres
    -  Midline Clocks
    - Generally things are pretty tidy, so anyone who needs standard bits like engine cover, trim, light covers etc etc etc, they might be of use to you.
    One is an 06 3 door, with a few more tasty bits and pieces on, but that has been sat for longer.  Again, engine itself is lunched.  Again, from the top of my head there is:
    - Heated Cloth interior in not bad condition
    - Black MFSW
    - Cat Back Stainless, although the cat itself was getting borderline on MOT passes, so maybe just the backbox of use
    - 18" Monzas
    - Neuspeed Intake
    - Twintercooler Setup
    - Reversing sensor setup rear bumper etc
    - Highline clocks
    There will be other decent bits on both - As I say, I am working a bit off memory at the minute.
    I just need the cars gone, so once I get started, really I just need it all out the way, so not especially bothered about getting top dollar for bits, I just need the space back, but know that the bits on them both are too good to let go for scrap.
    I am based just outside Walsall in the West Midlands, but work in Cardiff, so go there most weeks, and am happy to take stuff there (or meet people in between).
    Shout if any questions, and as I actually get stuff off I will get pictures up, but if people want me to get pictures of anything specific, let me know and I can do.  I am actually listing this right now when I am away from home with work for a few days, as thats the only way I actually get time to, but feel free to send me questions etc and Ill answer best I can, then send pics when I get back.
    I dont love posting car bits out - There is too much room for stuff to get damaged, go missing etc  - I would much rather collections, or meet you somewhere etc in an ideal world, but it can possibly be arranged on some stuff.
    Dan
    Superpro Aluminium Wishbone Kit and H&R Front ARB 28mm *PRICE REDUCED £350.00*
    £350.00
    Collection Only
    I'm selling a brand new boxed set of SuperPro Aluminium Front Wishbone set £495.00 and H&R front ARB 28mm (33258-2) £225.00, bought item's to fit on my Ed30 but I have since sold the ed30 so  these are now surplus to requirements.
    Cash on collection, will listen to sensible offers.
    Sorry no PayPal and will not split as need both items gone together please...
    Thanks for looking!
    Complete set of MK5 GTi rear lamps
    £25.00
    Collection Only
    A complete genuine set of rear lamps in excellent condition for golf MK5.
    There are for GTi model.
    • users Users: 3
    • guests Guests: 168
