Bushes
power flex anti-lift kit
This polyurethane bush fits into the rear position of the front arm and provides anti-lift properties and 1° of caster offset. It is designed to complement PFF85-501G that fits into the front position of the same arm to provide +/- 0.5° degrees of camber adjustment. This part replaces OE number: 1K0199231J, 1K0199232J & 1K0199231K,1K0199232K that includes the original bracket and rubber bush. This part replaces OE number: 1K0199231J, 1K0199232J & 1K0199231K,1K0199232K that includes the original bracket and rubber bush.
Added by Daled0111, on 2016-01-10 01:32:11
Well worth the investment
by aaronk.juju, on 2016-12-04 08:31:37
Stuck these on my Edition 30 Stage 2+ and they are great. Can be a big pain to remove old mounts as the inner stretch bolts heads can shear so be aware. Once I had the Powerflex mounts fitted and went for a test drive, I found it was well worth the money and time. Less wheel hop and less wheel spin. Traction has increase quite a lot and the car generally feels a lot more stable under acceleration and cornering. It does make the steering feel a fair bit heavier but not a problem for me. NVH is slightly increased but the benefits of the kit far outweigh this.
Powerful anti lift
by Svs, on 2017-07-16 14:57:58
Do this and the steady bar insert so much better and stable feeling with standard shocks springs watch tyre pressures steers like a mk 1 on rails and can handle speed bumps easy pleasure to drive watch out for seized bolts in rear bush bracket one into body is nearly always ok good luck
Daled0111, sciencegeek, bbfb10, 993BOY, cupra_matt, aaronk.juju, Ottis, Svs, wardyed30, Adrian, terrier,
