All Things MK6 R and GTI => MK6 Modifications & Technical Area => Topic started by: vambtech on October 05, 2019, 07:53:36 pm
I Have swapped a ccza engine for a bwa engine and have put it in swapped a few pipes around swapped a radiator all seems ok extended map sensor so it reaches also the alternator wiring. My problem is the engine cranks but will not fire. faults codes point towards cranks shaft sensor and cam POSITION sensor which is also why I believe it will not fire. I am thinking using the ccza block camshaft sensor and crankshaft sensor but would the gear ratios match. Please anybody with constructive knowledge participate or help how to complete this conversion so if anybody wants to do it in the future it may be possible. cant find anybody who has done this yet if anybody has please help me finish this off or point me in the right direction.
