All Things Mk5 => Mk5 General Area => Topic started by: moukie on September 19, 2020, 11:44:48 am
Hi, Car just failed its MOT due to a gear oil leak. It was suggested it is the flange sea requiring drive shaft removal (However... I inspected this morning I think it might be the bearing cover... Any suggestions or advice welcome.
https://photos.app.goo.gl/agxdjzSa25fzxHzbA
Steam clean it so you can find the leak easier
Or brake cleaner as a more available option.
The garage reckoned they had cleaned it with brake cleaner. Doesn’t look like it. Appears to be seeping from the bottom of the cap. I’m thinking it might need a beer shim and the revised cap
have a google, i've seen this problem before. sure its a shim and new cap mate.
