All Things Mk5 => Mk5 General Area => Topic started by: maxamplitude10 on January 13, 2020, 09:12:32 pm
My full closure function from key no longer works since battery disconnect/ code clearing?
Any ideas or is this a setting that requires Vagcom to re enable?
Have you tried resetting the one touch window control? When you disconnect your battery the car forgets where the top and bottom of the windows are so you need to tell it.
Wind the window all the way down holding the button on the door. Hold it for a couple of seconds then wind it back up until it closes. Again hold it for a couple of seconds. Now your window will go down and up with one touch from the door controls. I assume that this will then also reset the keyfob to be able to open and close remotely.
Well you live and learn. :smiley:
Yeah I reset the windows and no different.. However today the full closure has started working again so all good but no idea why?!!
Seemes to be a lot of odd things happen on these cars when changing or disconnecting a battery.
Is there an actual workshop procedure I wonder?
