All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Dave Y on August 08, 2019, 04:16:56 pm
As above is it worth fitting on a edition 30 with a stage 1 APR map ?
I like noise will this be loud ?
Anywhere doing a good deal on these ?
Hey Dave,
You won't notice a power increase unless the software is matched. May be worth considering an intake system, a full turbo-back and a few other little bits and going for stage 2 software? At least then you will benefit from the actual gains of the exhaust instead of just noise.
Contact AKS Tuning, and I will work out what we can do on the price for you :happy2:
Oh and we are also a BCS dealer if you wanted a quote.
the problem is my car has done 105,000 miles so i plan to stick with the APR stage 1.The previous owner had a Milltek centre piece welded in so i plan to get a catback system fitted.
Hi Dave
Why is a problem?
That’s not high mileage for its age.
Dan from Turners Performance advised to keep it as is so as not to put too much strain on the engine at this mileage.
