All Things Mk5 => Mk5 General Area => Topic started by: matski on November 07, 2010, 10:48:33 pm
Will a Mk6 instrument cluster fit in a Mk5? I know the Mk6 steering wheel fits.
Oly
I'm pretty sure it won't fit as the dash recess and cluster is a completely different shape? I think the Mk6 uses a different type of computer system which probably won't be compatible with the Mk5's system.
Someone on here is bound to know for sure though mate :happy2:
i asked the same question here is the LINK (http://www.mk5golfgti.co.uk/forum/index.php/topic,20969.msg286663.html#msg286663)
Welcome to the forum
Cheers, so if I retrofitted a Scirocco cluster it would work? Could I fit the entire cluster including the new white-on-black highline?
i was advised it might be possible but thier is to many things to change over and the later vw run on a different soft ware
What does it involve?
mm not sure to be honest..best sending Eddie-nL or Darren (mortygttdi) a pm who will advise you better :happy2:
Ok, I will do tomorrow, thanks
It will fit, you just need the right bits to make sure they work :happy2:
2010 Jetta in South America has mk5 interior, mk6 bits:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fgarthfred%2FDials_and_LEDs%2F2010_Jetta.jpg&hash=5dc6bc44e17e5b78bd5b8645c922f1a696eeafda)
Beat me to it Garth!!
It will fit but wont work without major electronic surgery :rolleye:
All you need is the right controllers. It's a relatively easy swap.... but not cheap :grin:
Garth do you know when the new black display came out? If its after 2007 youd have a nightmare recoding the cluster due to not being able to get the skc?? Even if you got hold of all the controllers?
It was after 2007 and you are correct, coding the clusters would be too difficult for most of us. There are companies out there who will do it (Star performance being one of them). As I said before, it would not be cheap as you'd have to replace most of the electronic controllers in the car to get everything talking together. You'd probably end up with more mk6 than mk5 components :grin:
Like I said mate major electronic surgery! :grin:
If you bought a new cluster it would come with the log in, read your current pin and code with vcds
So Ed if you got a new cluster with the black/white display with the skc you could put it in a lets say 2005 mk5 golf with no problems with it functioning??
Right if you could get the parts Rocco diesel 1K8 920 972AX or Rocco petrol 1K8 920 972X or Rocco R 1K8 920 972DX plus the newer golf mk5 Cecm 3C8 937 049AB plus the latest gateway, plus get it all coded you would have it working and no problems.
Most dealers will politely tell you to get knoted but if you speak to Hazzy Dayz they have the right Vas equipment and access to vw direct tech to do the job, the clusters are £280 new and the cecm is about £250 but I'm sure you will find the last part on ebay cheaper, you will need a new cluster for hazzy dayz to do the job.
Darren
Thanks alot Darren, I did send you an email, but don't worry about that now as I think thats cleared it up, except...whats a 'cecm'?!
Oly
Its the central electrics computer module that controls all the features on the car, without it your car would not run?
Darren
Are these part numbers the same as in an Audi? I have a friend that works for them and can get a good discount!!! :smiley:
No Audi's use totally different clusters, but you could ask him they should still be able to get hold of them.
Darren
can anyone find out our provide me with a vcds readout of whats installed in this car well not specailly that one, but a 2010 south american jetta like the above one so i can see what central electrics/convience gateway is installed? might be a long shot but any help is aprecaited! thanks
I You have MK5 golf caddy and what to put in complete cluster from MK6
I can code in with your original keys
Regardless of p/n
Can code 2013 A3 cluster in to 2004
Hello guys!
I'm new to the forum :)
I was looking for some help with fitting a Scirocco R cluster into my '05 MK5 GTI.
Any help on this would be appreciated!
Thanks.
where are you located?
Hi Eddie-NL,
I'm from Holland, "Zuid-Holland".
Any help through either the forum or email would be really great! I'm willing to pay for the effort ofcourse.
Thanks.
Roy
Any way to get in contact with you Eddie?
Thanks.
Pm Eddie NL & he will give you his contact no
Thanks, but I don't think I can send PM's just yet as I'm new to the forum.
Or did I miss the button somehow?
Hi guys,
Eddie can you please contact me?
Many thanks!
Roy
I have a Instrument cluster out of a 2010 Golf GTI if anyone needs one?
Want it gone so will take a sensible offer!
:drinking:
Would AVDI be able to revert an existing one to a virgin state?
