All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: raven8472 on August 24, 2015, 08:13:10 pm
Title: RNS 510 - Mix presets between FM AM ?
Post by: raven8472 on August 24, 2015, 08:13:10 pm
Does the RNS 510 allow you to have your radio presets from Either FM or AM on same page listed together so changed via steering wheel. So Kiss FM (1)  Talksport AM (2)  LBC FM (3) or do you have to switch bands to go between two opposing stations.
Wasnt sure if this has been answered before so apologies if im repeating.
Title: Re: RNS 510 - Mix presets between FM AM ?
Post by: Shoduchi on August 24, 2015, 08:16:33 pm
Yeah, you can. :happy2:
Post by: raven8472 on August 24, 2015, 08:22:39 pm
Thanks for the reply. Guessing the Dab RNS 510 would be fine as the presets are all together.
Post by: Shoduchi on August 24, 2015, 08:24:15 pm
I don't have a DAB version but should be like that, yes.
Post by: bluebert92 on August 27, 2015, 01:40:50 pm
Mine has 1: Talksport 2: Radio 1 ect, so it can be done -
Post by: Shoduchi on August 27, 2015, 02:22:53 pm
DAB version?
Post by: bluebert92 on August 27, 2015, 05:08:16 pm
Its not DAB, but my presets 1-6 including a variety of AM/ FM
Post by: Shoduchi on August 27, 2015, 05:55:02 pm
Ok, I'll have to check then. :confused:
Post by: bluebert92 on August 27, 2015, 06:35:17 pm
Mine is a version P if I'm not mistaken
Post by: Shoduchi on August 27, 2015, 08:01:15 pm
At the moment I only have access to my P version as well. From memory when I press Band to access AM frequencies the radio changes the screen to show different presets, but I don't really listen to AM radios in my country, so I might be wrong.
Post by: bluebert92 on August 27, 2015, 10:19:21 pm
Ill have to double check that on mine, not sure ive ever specifically selected AM or FM I use it quite simply in fairness.
Post by: Shoduchi on September 18, 2015, 06:34:00 pm
I've finally remembered to check this and it's possible to mix AM and FM stations. Sorry for misleading in the beginning. :ashamed:
