All Things Mk5 => Mk5 General Area => Topic started by: Rob1 on August 25, 2015, 03:37:38 pm
Title: Fitting W and Y Tyre ratings to the same vechile
Post by: Rob1 on August 25, 2015, 03:37:38 pm
Hi all as per the title, my car currently has Y rating tyres all round but considering purchasing a set of new W rating tyres for the front, would this pose a problem or is it a safe to fit different rated tyres. Naturally i dont intend to go over the speed ratings for each respective tyres
Thanks Rob1
Title: Re: Fitting W and Y Tyre ratings to the same vechile
Post by: Rasco on August 25, 2015, 03:49:36 pm
don't mix, I believe it's illegal to have different speed rated tyres on the same car? not sure could be total b*llocks.....
Post by: Andy on August 25, 2015, 04:05:16 pm
On yours Rob if your still in the tdi it's fine as long as the load number is the same or higher of which is the same if you put am odd tyre on
Post by: dronners on August 25, 2015, 11:35:22 pm
long as its the same on each axle it will likely be fine
Post by: Rob1 on August 26, 2015, 06:45:14 am
Ok cheers guys I bought the Y rated tyre
