All Things Mk5 => Mk5 General Area => Topic started by: Daled0111 on August 31, 2015, 07:16:02 pm
Title: Coolant temp sensor
Post by: Daled0111 on August 31, 2015, 07:16:02 pm
Hello I have change my coolant temp sensor that is near the batter area and I need to change the other one but can't seem to see it does anybody know where the other sensor is
Title: Re: Coolant temp sensor
Post by: dazza on August 31, 2015, 07:31:32 pm
This should help
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/19-WATER-Coolant_Temperature_Sensors_Replacement/19-WATER-Coolant_Temperature_Sensors_Replacement.htm
Post by: Madone on September 01, 2015, 11:12:29 am
I changed both, the one by the battery is easy, the one under the thermostat isn't easy. You need to remove the alternator and tensioner. It's tight but possible.
