All Things Mk5 => Mk5 General Area => Topic started by: Panthera on September 04, 2015, 08:59:16 am
Title: DV making a Chewww noise
Post by: Panthera on September 04, 2015, 08:59:16 am
Recently, when I change gear with half throttle (not thrashing it) the DV(?) seems to be making a 'chewww' type of noise. I mentioned this to the specialist that I use, who did a diagnostic check and there was no fault found.  Also if i accelerate in 3rd from 2-3000 light/mid throttle and don't change gear i also hear this noise. Is this a sign that my DV or something connected is on its last legs?
the GTi is due for it 80k service in about 400miles (according to the dash warning) so  i will mention it to them again.
I will post some pictures on my GTi now the Bilstein B12 Pro kit has now settled at some point over the weekend.   :happy2:
Darren
Title: Re: DV making a Chewww noise
Post by: K9 on September 04, 2015, 10:15:16 am
i'm having the same sound. it sound like a small blow off valve when loading the turbo up and letting of
Post by: GTIEagles on September 04, 2015, 06:29:20 pm
I also get this only when the engine is cold mine completely goes once warm.
Post by: Dan_FR on September 04, 2015, 08:56:59 pm
Could be the way you are coming on/off the throttle causing the DV not to open since its operation is controlled by the ecu... A video would help!
