All Things Mk5 => Mk5 General Area => Topic started by: K9 on September 04, 2015, 10:34:08 am
Hey guys. Ordered new reg. plates without the holes so thought i do give the magnets a go. so ordered 20 rare earth magnets 50N.
how would you recommend doing this?
readed this http://www.mk5golfgti.co.uk/forum/index.php?topic=12447.0
but how do he attatch the alu insert to the reg. plate? can it be done without the alu insert? glue the magnets to the alu reg. plates back?
I used this guide when I did the same thing. The only problem is the magnets corrode until there is nothing left. When it rains the felt gets wet and stops wet for quite a while which holds moisture against them.
I ended up trying the double sided suckers but ultimately went back to using the number plate plinth and sticky strips.
Bought 2 types of epox glue. one 4min and other 5min. no idea wich one to use :surprised: one says plastic welding and other Epoxy kit
