All Things Mk5 => Mk5 General Area => Topic started by: RedGolfDom on September 06, 2015, 05:29:29 pm
Will r32 or even edition 30 brakes fit my 1.4 tsi gt sport? Got quite a bit of power now and feeling the brakes need improving next so seeing if they'll fit
The 1.4 TSI with 170 HP should already have the same brake discs as the GTI, i.e., 312 mm discs. If that's not your case you just need to get front caliper carriers from a GTI and 312 mm brake discs, the rest is the same.
You can also get the R32 front brake setup, since it's much better, but it also weights much more.
See what you really need. Better pads will do a lot of difference too. :wink:
Thanks mate I shall look into it!
