All Things Mk5 => Mk5 General Area => Topic started by: Alex.GTI on September 06, 2015, 11:45:45 pm
Title: R8's NGK red coils for GTI?
Post by: Alex.GTI on September 06, 2015, 11:45:45 pm
Hi all:
Firstly sorry for my English. I'm from Spain and my English isn't good.
I think that I have a problem with my ignition coils. One of them could be failing and making a misfire. So I want to change my 4 coils. I heard that the coils for the Audi R8 runs very good in GTI V. My car is stock but in future I would like to reprogram it to stage I.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.tapatalk-cdn.com%2F15%2F09%2F06%2Ffee11e3926292df7d79b7ee226c1a0a0.jpg&hash=b15f591834759d6a7a30992632070b54ec15ff0c)
What do you recommend me? How do they work? Can I put these ignition coils without problems? I have NGK sparks too.
Thank you so much!
Enviado desde mi iPhone utilizando Tapatalk
Title: Re: R8's NGK red coils for GTI?
Post by: rich83 on September 07, 2015, 01:00:53 am
Hi. Yes the R8 coilpacks will work fine. Spark plug NGK BKR7EIX are the ones to go for.
Rich
Post by: Alex.GTI on September 07, 2015, 01:39:56 am
Thank you, @rich83. Now I have in my car these spark plugs (New. Replaced 3 weeks ago):
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.tapatalk-cdn.com%2F15%2F09%2F06%2Fe44b9ff9ebc7592c0274fe4c0dfcce18.jpg&hash=8971c8d06351594175d246be7f70ab863f7f954c)
Is it absolutely necessary that the plugs are iridium?
Post by: rich83 on September 07, 2015, 01:47:52 am
They will be fine. Next time swap to the iridium 7s
Post by: PhilNUK on September 07, 2015, 07:56:08 am
Sorry to hijack the thread but I have noticed that when I accelerate hard it feels like I am getting a flat spot in 3rd gear. Its hard to describe.  Its like I am hitting a rev limiter.
Does it sound like I need to swap mine out to solve it?
Post by: GarethB on September 07, 2015, 09:20:34 pm
Is it misfiring?
Best to log with vcds to identify which cylinder is causing your problems  :happy2:
Post by: PhilNUK on September 07, 2015, 09:35:55 pm
Yeah I need to find someone who can help me get an error code up.  I can't tell if it's misfiring as not 100% sure what that feels like.  Its done it since I got the car 15k miles ago.
Have ordered the coil packs and plugs today
Post by: GarethB on September 07, 2015, 09:45:09 pm
Whereabouts are you based?
Data logging the car will identify any misfires or errors. You may be getting misfires that aren't enough to trigger a light on dash / fault code.
That seems to be my problem at present - which has now been identified as misfires on cylinder 3. Hopefully I can swap the coilpack and that'll sort it - only had the injectors changed 5 months ago.
Post by: PhilNUK on September 07, 2015, 10:16:09 pm
I am in Liverpool mate.
Yeah it's bothering me and always has that there is an issue there. Finally had other things sorted and decide I need to tackle this.  Saw the packs and plugs were relatively cheap so might be worth doing anyway as neither have been changed whilst under my ownership
Post by: GarethB on September 07, 2015, 10:20:25 pm
I'm in Kent - so a little trek  :signLOL:
Hope the new plugs & coils sort the issue mate  :happy2:
Post by: PhilNUK on September 07, 2015, 10:28:04 pm
Cheers mate...  Its a hard sensation to explain but it just kinda lulls....  I guess if you visualised the torque curve it would climb and then level off completely and then climb again. Just hope it's nothing more expensive and involved
Post by: Alex.GTI on September 07, 2015, 11:40:43 pm
Me neither have done a logging. The problem is when the car is in idle. I feel soft moves, like little vibrations... When driving the car is perfect and I don't detect any anomaly. Surely the problem is in the coils or in some injector. What do you think about?
Post by: PhilNUK on September 07, 2015, 11:57:42 pm
At idle mine sounds fine..  DV and PCV recently changed...  All sounds fine and feels fine until I accelerate hard and every time I do I get the flat spot. Usually when heading up a slip road onto a motorway so it kinda has to be taken into account when planning on accelerating hard
Post by: Alex.GTI on September 08, 2015, 12:15:02 am
Your problem could be in the fuel pump or in the N75 valve (I think). You should do a data logging with vag com.
Post by: Alex.GTI on September 10, 2015, 12:07:46 am
Finally I did a log with Vag-Com and found this error:
Knock Sensor (G66)
Is it a big problem? could this be causing the vibration at idle? Should I fix it immediately to avoid a bigger problem?
I thought it was because the ignition coils
Post by: Alex.GTI on September 10, 2015, 03:40:53 pm
Does someone know something about? :(
