All Things Mk5 => Mk5 General Area => Topic started by: jordan7050 on September 25, 2015, 05:52:39 pm
Title: Vagcom/vcds in Portsmouth/Southampton?
Post by: jordan7050 on September 25, 2015, 05:52:39 pm
Random one and probably unlikely but anyone with a vagcom/vcds in portsmouth/hampshire area?
thanks
Title: Re: Vagcom/vcds in Portsmouth/Southampton?
Post by: v4rley on September 25, 2015, 06:02:47 pm
There is a section dedicated for such request.
Look here (http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html)
If no luck im on the IOW if you get desperate  :wink:
Post by: jordan7050 on September 25, 2015, 06:04:18 pm
thanks for that  :happy2:
Post by: Mandy on September 25, 2015, 10:56:48 pm
What did you need doing?
Post by: jordan7050 on September 26, 2015, 12:30:00 am
I'm just wanting to check to make sure the cars running the way it should. I had a problem with cruise control, so got the stalk replaced. The light illuminates when the switch is in the on position (this was intermittent before) but when i press the set button nothing happens, i assume this is down to either a fault and/or the brake light switch. just want to know if theres any fault codes before replacing parts
Post by: Degudodger on September 26, 2015, 07:13:23 am
I'm in sunny Winchester so not a million miles from you. Drop me a PM if I can help.
