All Things Mk5 => Mk5 General Area => Topic started by: njdudsbury on October 16, 2015, 04:12:41 pm
Seems to run fine. Lumpy tick over and revs raise up then settle again. Any ideas what to check or change?
For info sat in loads of traffic last night, stop start for over an hour. But ran fine after on a 50 mile run
Replace the PCV
Just done the check with the dipstick. Dont change it much but you get a gush of air?
How to guide anywhere on here?
I have the same issue, even after replacing PCV with latest revision. I'm putting it down to exessive Carbon build up unless there are any other commonly known issues? Replacing the PCV is really simple, a couple of push fit breather hoses and some torx bolts. Takes about 10 minutes if that. It's located at the right hand front of the engine.
How much is pcv to buy?
About £30.
Dave
Mines the same at the moment! Tried everything and I'm putting it down to carbon build up!
All fixed. Pcv changed. Old one still working in a fashion but takes some air to make it pull in. Seems fine now. Thanks
Anyone got part number for latest revision of pcv? For my ed30 :)
There's a thread around with all the latest revision numbers, pcv, DV cam follower etc. do a search :)
