All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Tr0nic on October 23, 2015, 11:04:36 pm
Title: RNS 510 DAB Version
Post by: Tr0nic on October 23, 2015, 11:04:36 pm
Hi Guys !
I've finally decided that my RCD300 should go and make way for a nice RNS 510 with DAB+ and an SSD !
I'm doubting between the 1T0 035 686 E or F version ... (even an H version but I can't even find it on ETKA !  )
F should be slightly newer then E ?
Found them on ebay, priced like £650 for E and £880 for F version.
HELP :driver:
Can't find much information about what the differences are, what the best choice is !  :happy2:
If anyone can help me see it a bit clearer, I would be very grateful  :drinking:
Cheers !
Title: Re: RNS 510 DAB Version
Post by: Deako on October 24, 2015, 03:32:23 am
Seems expensive. I paid £439 for an R SSD but without DAB.
Post by: SI-R32 on October 24, 2015, 04:05:05 am
Chasing newer and newer versions is pointless,  did that with standard 510,  3 different versions made bugger all difference,  now have 686c dab,  so no ssd but still no difference to my oem b version I started with,  yes the screen is led back lit,  do you notice,  not one bit,  just get cheapest dab you can as in 3 months they'll be another 100 new versions as vw pump them out left right and center changing the letter on the end for little pointless reasons
Post by: cenobytez on November 03, 2015, 12:41:36 pm
dont forget that you will also need an aeriel convertor cable as the 510 has a different connector
Post by: Degudodger on November 06, 2015, 12:24:29 pm
And new gateway if your car is pre 2007.
