All Things Mk5 => Mk5 General Area => Topic started by: wilsy_ on November 03, 2015, 03:53:32 pm
Title: Fans further back after intercooler
Post by: wilsy_ on November 03, 2015, 03:53:32 pm
Fitted an airtec stage 2 intercooler a few days ago, and as the intercooler is fatter, the fans now sit further back into the engine bay?
Has anyone else noticed this?
Its currently causing a bit of wear to the throttle body pipe and one of the radiator pipes, which has me a little worried?
Title: Re: Fans further back after intercooler
Post by: beetie on November 03, 2015, 05:42:43 pm
I wouldn't have thought it was big enough to do that.
Have all the screws definitely been put in? There's a couple that hold the whole rad/intercooler pack forward
Go and see if you can pull it all forward,  if you can they have not been put back in. I wonder how I know this happens
Post by: Madone on November 03, 2015, 05:45:25 pm
Yes, it will be further back. That extra thickness has to go somewhere !, as long as the fans don't rub you are good to go.
Post by: wilsy_ on November 03, 2015, 07:19:01 pm
All screws are in, so i guess its a matter of trying to ajust pipes so they no longer rub.
Post by: Madone on November 03, 2015, 08:26:55 pm
I've got the same cooler, there is def less room but no where near the pipes, something sounds odd there
Post by: th3_f15t on November 03, 2015, 09:11:32 pm
I think on the mk5 platform you have to remove a bit of the foam padding on the front crash member to stop things rubbing? Might be what's causing yours to be pushed back so much...
Post by: vRSAlex on November 04, 2015, 02:34:50 pm
What he says.
Usually a little material on the plastic panel needs chopping to allow the AC condenser not to rub.
Post by: wilsy_ on November 06, 2015, 12:59:04 pm
I'll try that.
Have got the bumper etc of and have discovered the intercooler is where it should be at at the bottom, but not at the top. It can be pushed forward, but falls back straight away.
Turns out I've left the two bolts out that hold it in place. Face palm
Post by: th3_f15t on November 06, 2015, 06:24:07 pm
The classic left over bolts... :signLOL: We've all done it at some point!
Post by: beetie on November 06, 2015, 06:25:36 pm
Do I win anything
:-P
