All Things Mk5 => How to Guides / Troubleshooting => Topic started by: guyrocks on November 03, 2015, 11:14:08 pm
Title: ko4 turbo oil leak
Post by: guyrocks on November 03, 2015, 11:14:08 pm
As above could anyone help or know where this will be coming from
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss7%2Fguyhamilton1980%2FScreenshot_2015-11-03-23-02-56_zps39f56osg.png&hash=2abf19034f90cd19f3311df44a416b34d17cc473)
Title: Re: ko4 turbo oil leak
Post by: guyrocks on November 04, 2015, 12:06:00 pm
Anyone know of how much a turbo rebuild normally costs........ just a rough idea
Post by: DANBOY66 on November 04, 2015, 12:08:49 pm
beach buggy anti surge turbos are £400 rebuilt :wink:
Post by: jhook661 on November 04, 2015, 07:05:55 pm
Might be from rocker cover gasket or rear pcv valve have you changed your front pcv recently ?
Post by: guyrocks on November 04, 2015, 08:24:52 pm
No m8 I've not I was told by the garage it was fine when I was asking about it...... the valve that is not the oil
Post by: jhook661 on November 05, 2015, 04:27:41 pm
May worth sticking your hand down the back of the engine and feel just under the rear pcv valve if it's leaking out of there mine was
Post by: guyrocks on November 05, 2015, 08:17:54 pm
Will do cheers m8 fid you change your own
Post by: jhook661 on November 05, 2015, 09:13:07 pm
Yeah I changed mine myself simple job if your changing yours make sure you get one with the check valve in it I'm guessing you've got a edition 30 ?
Post by: guyrocks on November 05, 2015, 11:46:32 pm
Yer that's right m8 it's a fart on or easy job
