All Things Mk5 => Performance Modifications => Modifications & Technical Area => Revo Zone => Topic started by: edition30jmr on November 05, 2015, 12:23:40 pm
Hi guys recently had my ed30 revo'd, just wondering if my settings are correct for stage 2+ the car seems to run great just wondering if I can squeeze anything else from her :evilgrin:
Boost: 7
Timing: 5
Fueling: 4
Thanks :jumpmove:
I am guessing you had this set by a tuner ?, and they took logs whilst doing it ?, prob not wise to mess with it as they should have used he best settings.
I run boost 9, which is more aggressive, you could try that. Are you running a updated inter cooler ?, wouldn't change the timing. 5 is about right.
Fuel is about right, each car is different so if set by a tuner don't change it would be my advise !
Yeah tuner set it up with live logging etc! What are your settings yes I'm using a ths cooler, thinking of changing to peron next year!
Are you on the stock HPFP bud?
Loba Buddy
You can't run a stage 2+ map on a stock pump
