General => Detailing => Topic started by: Dave KG on December 20, 2008, 11:49:37 pm
Today's detail was on a rather nice two year old VW Golf GTi DSG, in grey metallic... The owner wanted the car cleaned and protected for the winter months, and also have the opportunity to see some detailing in action with emphasis on seeing and having a go at claying.
The car arrived looking like many cars on the roads at the moment, after a drive up the motorway - covered with salt!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0003.jpg&hash=1c8523ea3b2cd7ae53cb472d259e7cd4491bef76)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0004.jpg&hash=618251fa83b9d9b146c445f87731ebf55c83d9c1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0006.jpg&hash=a2e110bdf5b3b8b36afd189418e88b0f07f8cad7)
First tackled on the car were the wheels and arches... Meguiars APC cut 4:1 was sprayed using a foaming spray head into the wheel arches and allowed to dwell while the wheels were cleaned. Bilberry Wheel Cleaner, cut 4:1, was used to clean the wheels:
- Spray on
- Leave a moment to dwell
- Agitate the wheel insides using a long bursh, through the spokes to remove dirt
- Clean the wheel faces using a Swissvax Wheel Brush
- Rinse thoroughly using the pressure washer
It was clear at this stage that the owner of this car keeps it very well as no aggressive cleaners or tar removers were required to bring the wheels up spotless...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0073-1.jpg&hash=71b7310e25e512487ff38bae092cee128e76962d)
(after pic)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0076-1.jpg&hash=3de397758ee641215774103ab3b6042348d568aa)
(after pic)
Note the wheel insides cleaned easily here - can typically take a lot more effort where they have never been cleaned before:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0030.jpg&hash=689c407e2a5318b83086736871ae129f7d5d1fed)
The arches were rinsed out under pressure before rinsing the wheels, and using my hand along the insder of the arch rim to gently loosen trapped dirt where the arch liner goes in towards the wing panel, ensuring all dirt was removed from the arches... may seem stranhge to do that atthis time of year, but if a job is worth doing... :)
With the wheels and arches cleaned, it was on with the bodywork... Stu foamed and rinsed the bodywork first using Supa Snow foam and then with Bilt Hamber Acti-Foam (my preferred), just to show the owner the differences:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0008.jpg&hash=4726b2fca37b17d9a8249b312571f0574f779223)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0009.jpg&hash=a7506d4c8e2efcc56158dccb7974ee5ccf2c823c)
The car was then rinsed, removing most of the dirt without needing to use a mitt - the joys of foam :) The car was then washed using the two bucket method and some Meguiars Shampoo Plus, before being rinsed ready for claying.
Only a light clay was required here - Meguiars Mirror Glaze Blue Mild clay, using Last Touch as a clay lube. Light sweeping stroked and you could feel it pulling out contamination so keep going until the clay runs smooth... the owner of the car had a shot, was keen to learn this stage and picked the clay bar up nice and easily and happily worked on door :)
With the car clayted, it was time for the cleanse and protection stage for the paintwork... but first, a scan around the car using the Sun Gun revealed the dirver's rear door and rear 3/4 had notably more swirls and holograms than the rest of the car:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0010.jpg&hash=bbe1c9dbe7c9adfbcd985ac4a89aa79f15d79e8e)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0012.jpg&hash=434f7b4f8aac9e0e1025990567c006cc3b52ea32)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0014.jpg&hash=82a77394638c1dbc5d64643247164174587bf6f9)
Bodyshop repair here... so to get this to match with the rest of the car which was relatively swirl free bar some deeper RDS, these areas were machine polished by rotary using Menzerna PO106FA Final Finish before the cleasning stage... This tidied these areas up beautifully, much to the owner's delight, and ensured there weren't patches on the car with more swirls than the rest:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0015.jpg&hash=dd1c4fc4e7ac527ea56d362a5515a2c76b5fa936)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0018.jpg&hash=51553909a2458dd9406e635738e19c0487717ef9)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0019.jpg&hash=4620ec96268c809d1667b96e3a3a33e59d2c5726)
This was not a correcton detail, but I was keen to see these little bits corrected.
The paintwork was then cleansed, using Klasse AIO - a product I really like on silvers and greys (seems to leave a slightly "cold" gloss that suits these colours very well IMHO... Applied by hand, using medium pressure and worked for abiout one minute per 2' square section before being buffed off... This cleansed the paint and added a first layer of protection for added durability... and the car was looking good after this:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0023.jpg&hash=7ef10fe0ab20d028e4141a04156610c6076e184d)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0025.jpg&hash=e3834aef130f79caf19afbdceb55d4890dc0f8ed)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0026.jpg&hash=a3b5f64b773a1ccdd56613149652fc7109bb5160)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0028.jpg&hash=41e12c965cb344068269609ddf83dcb110a61a1b)
One the paintwork was cleased, it was prtoected using Collinite 476S wax, applied in a nice thin layer and removed after a few moments... keeping the layers thin to ensure ease of removal. Collinite was chosen for its proven durability for protection through the winter months.
The wheels were protected also with Collinite 476S - a product I have been testing on wheels of late, and have found to exceed the durability of most dedicated wheels waxes!! So after thorough testing its now going to see use in this department as well! Tyres were dressed with Meguiars Hot Shine applied by aplicator, and arches with Meguiars All Seasons Dressing:
The arch...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2F2008_1220GolfGTi0036.jpg&hash=f974b5f87cae44f7bebc6e407b4655cf52d86bf7)
Glass was cleaned using Meguiars Glass Cleaner Concentrate, plastics and rubbers with Black Wow (the front honeycomb grille took a good while to dress!).
The car finsihed, in the unit:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0041.jpg&hash=1998834d97d783a1a41886b1caacb45a62ae30c6)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0044.jpg&hash=4e94895debb65fa97d9c145ce4c13472cd8fed3e)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0049.jpg&hash=306259a1bcd6a3da3227a2fec963506d039f5ec7)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0046.jpg&hash=d89d016f074924b47ee7ce7d7fb16a4af2fc4936)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0048.jpg&hash=e828e8a07dc92b39ad6c4def9803fd15ac4bb7ac)
And outside for some final after shots :)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0060.jpg&hash=812a069227d57511baa5902b7c72fc7df81605a0)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0056.jpg&hash=66ef37a22db0cfe0e6157db95b0b80d5fe3678eb)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0052.jpg&hash=9811502167d0d0bfdbb9e36c62ce82beec61ecb1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0080-1.jpg&hash=856a11bfa2e3bb0a0795e96aad4cd33d5408e72d)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0084-1.jpg&hash=90dacc60aec61d89da097328d4132fbba3090bb8)
a little more arty...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0067.jpg&hash=07fe777b1caf429543cae321c07f46b7f6def859)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0071-1.jpg&hash=e4a657d40165bcd91fa9fc7e721071014b07df0a)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0078-1.jpg&hash=afe021258e9616898a318f544e131ad436aaeff9)
and a little more arty still... :)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0063.jpg&hash=d4b0685a20c7ee0e40cb7c1205dd017e6ccf7807)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDaveKG%2FGolfGTi%2FDsc_0061.jpg&hash=0323ce65f88110b6fb4a9ab54b6e068ebcde623c)
A very enjoyable day, and a lovely well cared for car to work on :)
top job there mate looks great, keep up the good work. ive been thinking about buying a wheel wax but you`ve convinced me to stick with the collinite. top job
Sweet mother of mercy! That's a detailed car.
I have poorboy's wheel sealant. Can I apply collys on top or is it not worth it?
great post just promiced myself a foam system for Christmas :happy2:
A great detail as always Dave, thanks for taking the time to post it up, i am sure a lot of people on here can use it for reference and to ogle. :drool:
Thanks Dave. :drinking: :santa:
That's always been my method Stealth :happy2: Love the Collinite, it's so easy to use and gives stunning results :happy2:
That's awesome!
Where are you based out of interest?
Car looks mint!!!
BUT!!..
What the hell is going on with the exhaust cut out of the rear bumper!! Errghhh..
looking good dave!
is the right hand side of the cut out not quite right?
I think the votex kit is meant to look like that?
votex or ed30?
Just around the exhaust tail pipes, looks like a 5 year old has cut it out..
oh right lol.
votex or ed30?
Ed30 got the votex kit :P
And I'm sure the cutout is meant to look like that... might just be the angle of the photo.
votex or ed30?
Nope, Votex and ED30 rear are quite different..
Votex..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2Fvotex-gti-5.jpg&hash=af2e65990957e49690475a51d19a727e9bcf3733)
ED30..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2F30ae_back.jpg&hash=328276e659483aadb27b1f3fa2cebe9f029eab1d)
This car looks like it has the ED30 rear bumper but with extra material cut away from the tail pipe exit..
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fo304%2Fjonnnny28%2FDsc_0080-1.jpg&hash=11e7c05b78bd02b1c6f2b4492b6c062d0951c458)
(sorry to be off topic by the way)
much prefer the ed30 one!
great detail :)
Oho! I always thought they were the same.
In any case, I would concur with your assessment looking at these new photos...
Great looking detail there Dave, you know your stuff. :happy2:
Not tried Colli myself, tried most other stuff and now a huge Zaino fan. Must get a tub and give it a go though to compare.
You can do, and it will add to the protection there. The Poorboys is good, so if you dont have Collinite then I wouldn't rush out and buy it, but if you have it, it will add some good extra protection from winter rubbish on the roads.
That's awesome!
I based between Dundee and Perth (my unit is in the countryside, 9 miles outside Dundee) :)
You can use it on top of Zaino if you like, but then you wouldn't be able to use any more Zaino on top of the Collinite as it wouldn't bond - so once you use it, there's no going back unless you cleanse the car all over again (with for example Zaino AIO).
I rate the Collinite's durability though and it has superb water beading and sheeting - tight little beads compared to the larger ones from Zaino... nothing more than a cosmetic effect but its one I quite like :)
A tad late but na very nice detail dave and a great write up :smiley:
Thanks for sharing with us.
Mike
Nice job as always Dave :happy2:
