All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: AJG09 on November 13, 2015, 05:52:12 pm
Mot next week and brake pad warning is on!
I read that there is only sensors on the front? and I know the fronts are fine as the car had new discs and pads on the front about 2000 miles ago...
How do I reset the warning light?
Also the brake fluid level is okay I already checked that
Cheers :smiley:
You can get the light coded out with vag com or if you take the n/s/f wheel of and check the wire of the pads is plugged in properly
Yeah its plugged in ok, that's why I'm puzzled a d thought Il just turn it off if it was possible.
Cheers now I need to find someone with vagcom :wink:
it isn't a MOT failure but worth checking the wiring :happy2:
Is it not!? Oh well if that's the case then I don't need to rush haha
