All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Bigjimknickers on November 19, 2015, 05:21:48 pm
Title: RNS-315, what's needed?
Post by: Bigjimknickers on November 19, 2015, 05:21:48 pm
Looking into an rns 315 for my golf, it currently has no bluetooth, no gps, no mic.
So my question is, the 315 has integrated BT am I right? So I'll need a gps aerial & a mic to install one on an 2006 GTI?
When I search for the 315 mic it comes up with a BT mic so now I'm getting confused as to what I need for a total install!
Also, is a 315 a good way to go? I want an OE looking radio, with sat nav & a good BT setup for hands free calls/music streaming.
I'm not convinced by the android systems, I think they would irritate me as I'm an apple fanboi!
Title: Re: RNS-315, what's needed?
Post by: Pashka on November 20, 2015, 05:03:33 pm
There is different version of 315, not all has BT integrated. I could supply you RNS315 with BT and DAB aswell.
Post by: Bigjimknickers on November 21, 2015, 08:20:43 pm
ok, can I get a quote? What else would I need? A mic? What one?
Post by: Pashka on November 24, 2015, 10:51:34 pm
330 with mic and loom plus GPS antenna if needed.
Post by: Bigjimknickers on January 05, 2016, 07:17:00 pm
Still got this pashka?
Post by: cenobytez on January 06, 2016, 01:35:17 pm
would you also need a canbus upgrade with going to a newer generation and an aeriel adaptor?
Post by: Bigjimknickers on February 13, 2016, 08:52:09 am
How difficult is it to tie the mic? Is it an OE one which goes overhead?
Post by: Pashka on February 13, 2016, 09:36:33 am
there is some work to do, just search on google, you will find the pictures how to do it. Yeap, it goes overhead.
Post by: Bigjimknickers on February 28, 2016, 08:22:33 am
Is it a definite that a can gateway will need an upgrade on an rns315 with dab & Bt on a 2006 gti?
Post by: Pashka on March 03, 2016, 11:48:38 am
For sure.
Post by: STU175 on March 01, 2020, 12:00:13 pm
For sure.
any one know if i would i need a different can on a 2008 gti pirelli?
Post by: terrier on March 01, 2020, 04:19:03 pm
For sure.
2008 will be ok Ive had march 07 and oct 07GTI, both were fine when updating to RCD510DAB and RNS510 :happy2:
Post by: STU175 on March 27, 2020, 05:47:36 pm
ok so i have fitted the unit and all works great apart from i cant access the radio via vcds.
i have tryed controllers radio and navigation but vcds wont talk to either of them.
is there something else i have to do?
i want to access it to change from cd changer to aux in and check it has rearview camera input option available
i could access the old radio fine
thanks stu
